nice set up
nice set up
i was hoping to be street tunning next weekend but i am having trouble with the dizzy.
either i get it figured out or ill have to go with an optical or a magnetic pickup crank trigger.
looking good
thanks
she 's comming along slowly. The machine shop should be done wih my distributer either today or monday.
once i get her running she'll get paint.
aaahhhhaaahahaha!
i got her running!
with alittle help from ford....
heres one for the r&d department.
http://img355.imageshack.us/img355/1...ture0511mz.jpg
http://img355.imageshack.us/img355/3...ture0528xm.jpg
I didn't get any pic's of the ford tfi before it was machined..
http://img82.imageshack.us/img82/6097/picture0539rp.jpg
http://img82.imageshack.us/img82/2393/picture0548lv.jpg
http://img355.imageshack.us/img355/9...ture0560fm.jpg
http://img355.imageshack.us/img355/2...ture0588dy.jpg
http://img115.imageshack.us/img115/9...ture0594ie.jpg
Originally Posted by 89turbo'ed
DUDE!!!! you fuking rock!!!! :rockon:
get us some more info on what you did there :thumbup:
Looks great.
well there isnt much to say on this mod except for it was easy and the price wasnt too bad.Quote:
Originally Posted by gfrg88
i paid $125 for the machine work.
too tell you the truth i got frustrated with the honda dist..
the dist. would'nt talk to the commander.
soo i had a ford dist. sittin around it had plenty of meat on it and it looked like it would be a good match.
i went to burts machine and told them i needed the base of the ford to mirror the honda 2 days later it was a perfect match.
the old a20 fired up right off.
just think of the possibilities.....svo ecu swap. other options such as mass air and tunner software.
I'm in love with your engine!
updated pic for you...
http://img218.imageshack.us/img218/7...ture0638qf.jpg
:) hotness, seeing your car is making me think of going turbo
heres another one.
http://img84.imageshack.us/img84/918/picture0649rd.jpg
nice!
how do you have that lil radiator on there. and are you afraid of the support not being there because you cut that top part of the engine bay where the hood latches to?
So no DIY info on getting that dis to fit... what car is it from?
Is the clearance between the cam bearing and the distributor that tight that it doesn't need any screws to hold it in place?
the radiator is mounted on 3 points for now and the support isn't there because these are progressive pic's i have'nt modified and installed it yet.
by the way its a bolt on peice not a cut out peice.
a20 there is not alote to tell...this part of the project you need to take it to a machinest.
all you have to do is tell them to match the honda dist from the base out to the cam key.remove the key and mill the ford shaft to fit the key.
make sure they have the cap and rotor of both so they can clock the key correctly. pay close attention to the cam key it is slightly off center to only fit one way.
a few years ago i turbo'ed the first ford tempo with the 2.3 hsc ohv and made about 250 hp to the wheels and is still currntly the worlds fastest :LOL: . i then bought my accord and took alote of The part's i had and built a turbo accord. this dist is from a 86 ford tempo, but you can also use parts from a svo mustang, hsc mustang,thunderbird turbo coupe and a ranger.
i am not good at write up's so i hope this will do.
i forgot... bb chevy mount i had to drill a new hole behind chevy hole.
http://img204.imageshack.us/img204/9...ture0586jb.jpg
so does it run???? what ecu are you using?? do you have build a conversion harness???
she's at the ideling stage of tunning, and I am still putting her back together.
I am waiting for servion to get back from las vegas to street tune then dyno tune.
i am using the holley commander 950 standalone and yea i had to make a harness for the altonator and starter wire.
I am guessing that what you are asking me is if i am using a ford ecu, no.
but it isn't that hard to pull a ecu and harness from a ford and adapt it to the honda.
it's just wires and sensors.
another progress pic....
http://img370.imageshack.us/img370/9...ture0690jv.jpg
dude im loving your car more and more :D
what else do you have, as in any internal parts???
the short block is fully built. JE 10.5:1 pistons eagle H beam rods acl bearings and the rotating assembly is fully ballanced. Everything else is brand new,oil pump,water pump and altonator.
head work will be the next thing i get done.
wow, 10.5:1 compression on a turbo set-up? that sounds like some good power is going to be produced right there.
holy shit dude, thats fuken awesome!!! so how much boost you planning on running?? what numbers are you looking for on the dyno?? :DQuote:
i should be able to hit 350-400 hp but we'll see...
as far as boost goes i'll do what it takes to get those #'s
