full bodied coil overs vs coil over sleeves
what are the pros and cons of each of them? ive got access to some konis and i can easily get the adjustable coil over sleeves or lowering springs to go with them. i also cant really find any shop willing to break up a set of them, and im about to put my car in the road within a month, and as far as i know, its way too low to a point where ill be hitting the ground too much. any input is greatly appreciated.
Re: full bodied coil overs vs coil over sleeves
You don't lose suspension travel when you lower a fullbodied coilover because the lower mount is usually threaded, unlike a coilover sleeve where you do lose travel.
Alex
i got sleevs and they ride like a bitch don't get them i going with fullbodied as some as i get a chance
Alex
but i thought if the spring was adjusted all the way to the bottom, its like riding on stock suspension. when you lower the car, your just making the stroke shorter then normal?
would konis survive thjis type of springs?
On a full bodied setup, you don't end up compressing the spring at all to lower (well, you can--it's called preload, but it's not necessary). So you can thread the lower mount (where the strut mounts to the car, not the spring perch), all the way up, and you haven't lost any travel, you've just slammed the car.
Alex
the only thing attracting me to a sleeve setup is purely its cost. sleeves cost next to nothing, and a set of full bodied coilovers cost me about 1k. and when one of them blows, thats when im in trouble.
full-bodied coilovers can usually be fixed(I know my HKS ones can) and are worlds better than sleeved style,save your money and go full bodied
Every single part of the D2 coilovers can be replaced and they are covered under a 1 year warranty, even if they are used in a racing application.
and we know of a shop that will break them up. :)
*Cough* Nolimitmotorsports *Cough*
im on the verge of getting the D2. damn you legend
YOur welcome :) .
If you're spending that kind of money, get a set of konis revalved and some ground control coilovers.
I wouldn't waste money on ksport/d2.
Alex
Alex
techncally he does not have to go d2/ksport he can go with whatever coilover he wants as long as he can find someone to mix and match them
Alex
Dude, seriously what is you problem with D2s. I have had nothing but good experiences with them. I know the Nissans dont due to well with them, but my car has had no problems. I have read many threads on H-T where people have been riding around for a more then a year or so with no problems. Also you tell me where to get some konis and I would have gone with them. If you meant to say Bilsteins then I dont really see the point in paying 1K for some struts when I can get a full bodied coilover for the same price. I chose to go a little more stiff then what I needed, but thats the dilemma with experimenting with new parts for a car. When Tein decides to split up kits I might consider that, but until then Bilsteins are to damn expensive for what they are.
People who have never have had coilovers love them...if you owned something better, you realize they're underdamped. Plus, with all the stories of people driving only a few days/weeks/months and then blowing them (even on honda-tech). I know of at least two friends who started out with them and quickly blew them up.
It's the same story for pretty much every entry level coilover: "zomg, these are the best evAr!!" Only after stepping up to something good does reality come apparent.
Alex
well i dont have a problem with getting tein kits split up. im getting quotes for the basic set up for 800 and the flex for 1300. im just a bit worried bout mounting issues. another thing is that the basic's arent adjustable but flex are so iunno =/ plus i got a quote from no limit for 925 shiped for the d2's so price is somthing of consideration
