Clean87sedan's High compression B18c1 build & swap thread!
Well.... As most of you may or may not know, I chose to go a different route with my car. The A20 is a champ and ran strong & hard since day 1, but with having one more quarter of auto mechanics in school Ive decided to do something BIG. Something I never planned to do with this thing cause I never thought Id be able to. Anyways back to the matter at hand..
I picked up a 95 spec b18c1 motor that came with the following in it. I just decided to tear it down and see if everything is good to go because bought off CL..
Im working on the transmission & some other stuff currently and the loaded engine block & head is the only thing I purchased on CL.
Specs UPDATED as of November 16, 2017
Prior to current engine rebuild;
Dyno tuned in 80 degree weather on v-power 92 pump gas;
206 whp @ 8600 Rpms
143 wtq @ 7000 Rpms
Limiter set @ 8600
Launch control @ 5000
Engine Block;
B18c1 GSR
block bore 81.5mm
Deck shaved .010"
Balanced & polished GSR crank
Acl race rod bearings
Acl race main bearings
Manley forged rods
ARP rod bolts
New OEM main bolts
JE forged pistons 11.5:1 Compression (EST. 12.5:1 final CR ratio)
OEM water pump, tensioner, oil pump, seals & gaskets & so on..
Gates blue racing timing belt
Golden Eagle oil squirter plugs
Cylinder Head;
95 B18c1 milled .018"
port and polished IN/EX ports w/ port matched intake manifold
Ferrea bronze valve guides
Ferrea exhaust/intake valves (dished / stock size)
Ferrea valve stem seals
Skunk2 Lma's
Ferrea valve keepers
ARP head studs
Supertech springs and retainers (85lb)
Brian Crower Stage 2 NA cams
Skunk2 Pro Series Adj. cam gears
98 SPEC B16b Type R valve cover
Edelbrock Victor X intake manifold
Skunk2 Thermal intake manifold/ throttle body gaskets
66mm Skunk2 Alpha throttle body
Transmission;
93 Integra YS1 case
99 Civic SI B16a2 4.4 FD w/ matching 1-4 gear set & cable LS 5th (slightly shorter than hydro LS 5th)
Mfactory B16 Helical LSD
Synchrotech Carbon Synchro kit & new bearings/ seals
Fidanza 8 lb aluminum flywheel
Competition Clutch stage 1.5 clutch kit
ARP flywheel bolts & Pressure plate bolts
Factory magnetic drain plug (Trans & Motor)
Other misc;
Innovate 60A conversion mounts
TODA rep 1320 header
RC 310cc Injectors
Professional Products harmonic single drive crank pulley
so on and so on...
Re: Clean87sedan's High compression B18c1 build & swap thread!
Sounds like a great start, cant wait to see pics, as i think im gonna start saving for a swap myself!
Gonna be a sweet set up man. Fast, cool looking and awesome sounding
Brodie, that is a really nice sounding motor build. Im officially jealous! Can't wait to see it go in, should be fun!
As much as i hate you for giving in i do like it! Keep the quality there man! A+ stuff.
Tdurr
Yeah I know lol I love my a20 and I put some serious work into it but stuff keeps breaking that I repair over and over and over because parts suck to find or even get. And I figure i was gonna do this to an a20 (high compression and all that) but the gains wouldn't be as nice for the price as it would be with this engine so changing it up and b series stuff is a lot easier and cheaper and they're stronger motor & trans wise
Got the innovate conversion mounts. 60a
http://uploads.tapatalk-cdn.com/2016...637780ca6a.jpg
The block didn't have oil squirters in it because of the forged Pistons they hit the bottoms of the piston, so I got GE oil squirter plugs which fit great and will raise oil pressure too
http://uploads.tapatalk-cdn.com/2016...e46e8012f1.jpg
http://uploads.tapatalk-cdn.com/2016...05038de3fb.jpg
The head was ported & polished on both intake & exhaust and the intake manifold was port matched and smoothed out. So I didn't want the runners to be all cast rough so I sanded the runners smooth
http://uploads.tapatalk-cdn.com/2016...db1d662184.jpg
Guy gave me a stage 1.5 competition clutch with motor but I needed a flywheel. Did some hunting and I loved my 8lb one on the a20 so found a fidanza 8lb flywheel to match
http://uploads.tapatalk-cdn.com/2016...98c50cf2e6.jpg
Also needed a header. Wanted something that wasn't cheaply made and nothing that had huge runners hanging low so found this 1320 performance toda style rep header. Big tube with a 2.5" collector
http://uploads.tapatalk-cdn.com/2016...38e80118f1.jpg
Now onto the transmission!
I am using a 92-93 integra YS1 cable transmission casing with 99 civic si B16a gears, main & countershafts and 4.4 final drive. I also put the LS 5th in to help freeway driving.
The transmission was from a buddy of mine who blew the diff and pieces of it out the rear of the case and he said it was toast most likely but he didn't open it up. I opened it and cleaned out the debris and luckily somehow all the gears and internals were Good! Well besides he diff... Anyways. Here's pics of the damage done
http://uploads.tapatalk-cdn.com/2016...74c55d76b2.jpg
http://uploads.tapatalk-cdn.com/2016...6a7b8ff0c0.jpg
http://uploads.tapatalk-cdn.com/2016...0517de4233.jpg
http://uploads.tapatalk-cdn.com/2016...d2eeba84b7.jpg
http://uploads.tapatalk-cdn.com/2016...1bb1b43631.jpg
http://uploads.tapatalk-cdn.com/2016...659a4673a1.jpg
I took all the internals, cleaned them up, got a rebuild kit from synchrotech with the carbon pro series synchros and all new bearings & seals. Also figured at this time and knew I didn't want this to happen again, I got a Mfactory helical LSD for the trans as well. This setup all together is a ys1 case, b16a2 1-4th, main & cohntershaft, 4.4 final drive, LS 5th and Mfactory LSD
http://uploads.tapatalk-cdn.com/2016...199b9a04cd.jpg
http://uploads.tapatalk-cdn.com/2016...143ff37f1d.jpg
Painted the case
http://uploads.tapatalk-cdn.com/2016...58cf6ad852.jpg
http://uploads.tapatalk-cdn.com/2016...bd31ebb88a.jpg
I went ahead and decided to rip the head off to see the guts of this thing and wanted to make sure everything is done right and ready to go since I bought it second hand. Man.. These pistons are mad dome!
http://uploads.tapatalk-cdn.com/2016...f7f1d0e79c.jpg
http://uploads.tapatalk-cdn.com/2016...0b1690822a.jpg
http://uploads.tapatalk-cdn.com/2016...61b7b53bc0.jpg
http://uploads.tapatalk-cdn.com/2016...a03585f46b.jpg
http://uploads.tapatalk-cdn.com/2016...31b0dbed3e.jpg
http://uploads.tapatalk-cdn.com/2016...1d5926de81.jpg
The head had some good scratches on the surface from the guy putting it on I'm guessing so I took it to a shop to get resurfaced. Come to find out the surface was warped a little, the head failed a vacuum test and came to find out the valves weren't installed right by previous guy. All good now though and holds vacuum!
Before
http://uploads.tapatalk-cdn.com/2016...9dcaad534a.jpg
After. Don't mind the oil on the surface. http://uploads.tapatalk-cdn.com/2016...56d5af9cd6.jpg
I'd be wanting to manually measure the CR just to be safe .
When i had my B20a rebuilt the measured CR end ended up at nearly 13:1 even though the pistons are 10.5:1 wisecos.
Slight difference in rod length , head and block skimmed just enough to make them flat gave a big jump .
Made it to high for the pump gas available to me .
Ended up having to take material off the tops of the pistons to get down to 10.8:1
Will be interesting to compare numbers when they are both running and tuned .
Fully tweaked b18C v fully tweaked B20a
Hauntd ca3
Yeah im looking at these saying "these are only 11.5:1????" Lol and my cylinder head is milled enough to bump the cr up another like .5 to that so.. Yeah I'm gonna have to clay the engine for clearance and see what I get
what sort of gas do you have available ?
If i had 98 available i probably wouldnt have worried about dropping to 10.8:1
Probably 11.5 - 12 :1 , but since 95 is the best i can get in town at the moment and is available pretty much anywhere i go , i went a bit lower .
And gas quality varies quite a bit down this end of the world so erred on the side of safety , i cant afford 10k to rebuild from scratch if the engine gets damaged from detonation .
Hauntd ca3
I run shell V power 92. There's a trick fuel station out here too that I can get gas from if I plan on beating it up at the track or something. Wouldn't hurt. My friend has a 12.7:1 d16 and he runs shell premium with no issues. I think 11.5 is the highest I would go on anything cause any higher 92 won't cut it
Update.. Well kinda..
Tore the block down to nothing to check everything since I bought it all together. Glad I did.. Second ring on cylinder 1 was chipped. Nothin major I'm guessing the ring expander tool chipped it cause that's what it looked like and I almost did the same thing lol. Anyways, tore it apart, cleaned and inspected everything and reinstalled all ready for the head to go on after more measurements and checking piston to valve clearance.
http://uploads.tapatalk-cdn.com/2016...24becd1431.jpg
http://uploads.tapatalk-cdn.com/2016...c0af3839ff.jpg
http://uploads.tapatalk-cdn.com/2016...c522f00834.jpg
http://uploads.tapatalk-cdn.com/2016...3c826cbbc8.jpg
http://uploads.tapatalk-cdn.com/2016...974c65bc18.jpg
http://uploads.tapatalk-cdn.com/2016...d2d712c1f7.jpg
Chasing the threads for precise torque
http://uploads.tapatalk-cdn.com/2016...fe08979730.jpg
http://uploads.tapatalk-cdn.com/2016...6a314573fc.jpg
http://uploads.tapatalk-cdn.com/2016...808af3508e.jpg
http://uploads.tapatalk-cdn.com/2016...759a152386.jpg
swap this in the car already!
Tdurr
Soon dawg. Soon
Looking good! Interesting to see some of the things you find when tearing down someone else's work.
I'm actually thinking of the same header myself too.
I'm surprised that it has such a small crank girdle , even the b20a has a full length one.
Are the crank oil feeds in the block of the later b series ? Just wondering since the b20a has them in the girdle.
hey if you didnt put sealant(like rtv or anything) you should pull ur oil pan and:
a. paint it with a fresh coat of black(because we all like pretty thing)
b.paint a white line around the top of it so if you develop any leaks you can pinpoint them right away.
just food for thought. build looks great tho!
Tdurr
I put Honda bond RTV on the pan and multiple other gaskets
Hauntd ca3
They're under the main bearings in the block yes
Engine is together! Just bolting on like dizzy and other stuff :) everything internal is done. Timing is set, Valve lash is set, it's getting close to bolting the trans up to it
http://uploads.tapatalk-cdn.com/2016...7d136b4503.jpg
