header exhaust flange
does anybody know where i can get a header exhaust flange that mates to the head? on my header it was cracked and welded, and the heat warpped the flange pretty badly. i tried to heat it up with a torch and bend it straight but its just to badly bent.
Did they weld the header while it was still on the head?... usually you do it that way to avoid warping.
http://www.stainlessworks.net/Header%20Flanges.htm
you can send them your exhaust gasket or template and they'll make you one in stainless or mild steel.
Id send a gasket/template to WeirRacing on homemadeturbo.com (look at the classifieds section), get a 1/2" weld flange and that wont warp wether you weld it bolted to the head or not... prolly cost you $35
