obd0driver
I may have a cluster. Ill check in the am
Sent from my SM-N920P using Tapatalk
Cool . I need to ask you about the intake manifold since I'm running a stock intake manifold are there any OBD1 sensors on the B16 manifold I would need for 0bd1
OBD1 map sensors are on the the tb and obd0 is in the black box so you'll have to extend the wires to reach but that's about it
obd0driver
Cool thanks
6 Attachment(s)
Leaky rear brake cylinders replaced. And stainless brake lines installed. Glad that's done:beat:
3 Attachment(s)
Seems like everytime I turn around I got some kind of leak.power steering pump seal hell of a mess got a rebuild kit
Keep going. You'll get there.
Shane86
+30 year old car, you expect things like seals to last forever?
gp02a0083
no it seems like when these cars break down multiple things happen in a row. Fix one problem to find another
its worth it once everything is done.
MessyHonda
I know I think I'm getting pretty close
4 Attachment(s)
Swap to the 89 cluster today and I can say I now have a VSS signal it is pretty accurate. It even shows what gear I'm in based on RPMs and speed .And I'm seeing my old cluster and that I never seen the check engine light on because someone remove the bulb
3 Attachment(s)
To get a vss signal to your 86 cluster you only need to swap the plastic white box from a 89 cluster I give Rendon LXI the credit thanks bro
Great tip.
Get that afr down!
Oldblueaccord
Great tip.
Get that afr down!
Thanks. I know been having problems with the sensor/ signal.i switched from pin D14 to pin B6 for a more Clear signal seems to be working great now
2 Attachment(s)
Well the water pumps leaking I don't know how I forgot to replace that and the timing belt when I had it all apart. One step forward two steps back:uh: as soon as I can get all the leaks and bugs fixed I might be able to put a turbo on it one day
8 Attachment(s)
You really can't tell much of a difference but I did a wire tuck on one side without cutting or extending any wires. Still got a lot of work to do
8 Attachment(s)
Tucking wires little by little
4 Attachment(s)
I'm trying to wire in a OBD1 throttle body map sensor .I know the pin out on the OBD1 clip. But I need to know the signal ground and Power on the OBD0 stock harness side. I've been testing with a stock OBD1 sensor tried different wiring combinations and having no luck possibly a bad sensor. Found wire diagram just waiting on sensor
2 Attachment(s)
From the testing I'm done I say that you can not use a obd1 throttle body map sensor as a firewall map sensor. it didn't work for me.
when you say map sensor are you meaning the Throttle position sensor. Or you mean a Manifold pressure sensor?
Oldblueaccord
Map manifold pressure sensor. Obd1 throttle body map sensor + Mount to firewall= no go
4 Attachment(s)
Fuse box relocated. I hate wires:banghead: it's too hot in Florida
3 Attachment(s)
rushell
looks like fun
yes sir it has been a real chore. I think I did it ass backwards I relocated the fusebox before I relocated the battery to the trunk/hatchback. I just need a good sealed battery box before I move it
3 Attachment(s)
Wires cleaned up and fuse box mounted
