Pull the whole engine and tranny out. Lot easier. You can even get away with just pulling 1 cv, then lifting the pair at an angle untill you can get to the passenger side cv, then just pop it out and there's your tranny!
Today i removed the axles and started to remove the tranny. It was hanging on something and i found it was a thin metal covering plate on the side. It attaches to the tranny case then goes around the engine side of the flywheel. Its attached by two 10mm bolts on the front and back. Why in the world is it attached that way? My tranny has been worked on before by a shop, but they would have had to hold the tranny and engine together then put this thing on in between it and then slap on bottom mounting on top of it.
Anyways i worked on it till 11 tonight but tomorrow i have to get it off and need to borrow a 10mm wrench to get that covering off, i have lost mine.
That's the dust-shield for the clutch. You can remove that first if you want to.
If you don't have a 10mm, you're gonna be in trouble! :tongue:
I would make sure the flywheel cover is back on when you start driving it at least. I mean you don't want a rock getting jammed up in your bellhousing, knocking off your ring gear, or damaging the flywheel or something, do you?
What a F-ing coincidence that your DX and LXi cars are the same color as mine when I did my swap, except mine were both 5spds. Good Luck man and least you got a garage to work in I had to do it outside:cheers:
8, 10, 12, 14mm are a must!!!
Here's the link for my swap if your interested https://www.3geez.com/forum/showthread.php?t=67669
The problem we realized was that you cant see the rear bolt untill you get then tranny separated from the engine a little bit. I could have removed the front one.
So i removed that dust shield, and it separated even more but i cannot for the life of me get it apart.
http://honda.conozo.com/pics_3geez/day6%20%280%29.JPG
http://honda.conozo.com/pics_3geez/day6%20%281%29.JPG
http://honda.conozo.com/pics_3geez/day6%20%282%29.JPG
Shouldn't this be far enough, i cannot move it any further without hitting the side wall. In the shop manual it says slide off dowel pins and lower. There is at least a 1 inch gap above the dowel pins at times when struggling with it. that. I'm hoping you can tell me something obvious because this is getting ridiculous.
remove the timing belt engine mount so you can tilt the engine.
yeah its cought up on the input shaft.. need to tilt it out a bit more... my whole engine was crooked when i did it so it was low enough to slide outlol
Thanks for the tip. Once i shoehorned the engine i had to pull it off about 7 inches before it disconnected but I got it out and hopefully i didnt bend anything.
http://honda.conozo.com/pics_3geez/day6%20%283%29.JPG
I hear the manual tranny is easier, i hope so.
More and more I try to remove things the way they were put into the car at the factory; much more easier than other ways.
The manual tranny weighs like 1/3 of that tragedy of a gearbox. It's MUCH easier to get installed. The input shaft is also much shorter and theres a ton more room to fit it in there.
yeah looks good so far...hope you get a nice clutch and flywheel
Alright guys, this project is still in the works. I havent touched either car since my last post. Since then i have done a lot of work on remodeling the home, grown my business, had another kid, and now its time to get this thing working again. I cant stand driving the 01 Windstar minivan anymore. Its a gas hog and handles fat walrus on ice. Give me some motivation to get this thing working by the summers end.
By the way i plan on doing a full restoration, not just swapping parts, so its a lot more work than the typical carb to fi conversion.
I have a confession, I have a nice 3G sitting in my garage that I have neglected. I want to fix it up but I hardly have had the time in the past year, but now I'm getting serious about getting it up and running. I'm going to sell a crappy van after ford completes the recall hopefully in April, then use that money to restore this car.
I told my 3 year old son that we would go out and get ice cream when we fix the Honda and he reminds me everyday about it. He thinks is going to be a 20 min fix.
So I'm serious about getting this project done this summer, i really miss driving it and I'm tired of these gas prices in a 17mpg van.
haha your son sounds like my little nephew. congradulations on the home buisness and new baby! sounds like you have a nice life going for you man. get some work done on that baby though! this would be way beter gas mileage then the van and you would look cooler in it :) theres some motivation for ya!
It took me about three weeks but i finally got the garage cleaned up last night. I had piles of stuff under the cars, around the cars, ontop of the cars, and some in the cars. There were four 5 gallon buckets i filled up with saw dust with all the wood project and table saw use. I also added more lights toward the garage door, there wasnt any on that side of the garage so it was pretty dark, but now its got 12 light bulbs. Heck it even pretty bright under the cars, lol. So now there is at least 3 feet of clear space all around each car. I'm also hiring my neighbor kid to help me, i have a simple jobs for him such as moving parts over or taking out the tranny so i can rebuild it. I've wanted to do it all myself but i simply will never get it done if i try to do it all by myself so thats why i need the help.
http://honda.conozo.com/pics_3geez/0626122239.jpg
http://honda.conozo.com/pics_3geez/0626122239a.jpg
ooo that looks fun. wish i could help
your car brings back memories of when you got married and you used your 3gee. I wish i can do that too...lol
Hah yes, sometime I'll create a memories in the honda thread.
It was worked on a little today and I found a few spots of rust that concern me. I initially was going to do rust repair but then after a couple years I just wanted to get it running and fix the rust later. But now after today I may have to fix some rust spots before getting it running such as if ther is a rust spot under the gas tank and hard to reach areas like that. So I was looking at the welders available and am not sure what to get. I only have 120v outlets in the garage but not sure what type is best for a novice and simple projects. I'm reading the other welder threads for info.
Harbor Freight is running a deal on a simple Flux Cored Mig machine, I think it's like $99 for it. Just make sure you do a lot of practicing on spare metal before you start to weld on your own. And get good at contour grinding.
My brother-in-law has a small welder, i don't know what kind but we'll make it work for the few spots I need it in.
This morning I was going to take the manual transmission out of the parts car and got stuck on the bottom mount. I took 4 bolts out and it seems to be hanging on the rubber mount. Any tips?
http://honda.conozo.com/pics_3geez/0...20(Medium).jpg
take off the crossmember?
