Unsprung Weight
Unsprung weight is the weight of all the components not supported by the cars suspension. This usually includes: wheels, tires, brakes, uprights, bearings, and the shock or strut assembly plus part of weight of control arms and axle. Lower unsprung weight makes it easier for the suspension to keep the tire in contact with the road over uneven surfaces. The weight of wheels and tires is especially important because it not only contributes to unsprung weight, but it also rotates. Reducing rotating mass improves acceleration and reduces the load on brakes.
Wheel weight links
www.superhonda.com/tech/wheel_weights.html
www.audiworld.com/tech/wheel22.shtml
www.miata.net/faq/wheel_weights.html
www.wheelweights.net/
http://www.konigwheels.com/catalog_l...m?categoryid=1
Wheel Offset
Offset measures the distance between the surface of the wheel that mounts to the hub to the vertical centerline of the wheel.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
This site is useful if you want to find out something specific.
www.wheelspecs.com
Many tire weights are available at tirerack under the specs button for each tire in each size
Wheel and Tires Sizes
OEM Wheels
Stock 14x5.5 45 mm offset 4 x 100 mm bolt pattern
88-89 OEM 14" alloy wheels weigh 17.1 lbs (thanks CAH)
Stock 13x5.5 4 x 100 mm bolt pattern
Civic and Integra wheels fit
13" wheels do not fit on 88-89 fuel injected cars because of the larger front brakes
Tire diameter calculator
http://www.miata.net/garage/tirecalc.html
...or do it yourself
(wheel diameter [inches])+2*(aspect ratio)*(section width [mm])*(1/25.4)
example: 195-60R14: 14+2*0.60*195*(1/25.4)=23.12
The exact outer diameter can be found for a specific tire using the revs/mile data available on tirerack:
diameter = (5280*12)/((rev/mile)*3.1415926)
Tire sizes (use offset 40-45 mm wheels; slightly lower offsets may work in some situations)
FORMAT [size] [outer diameter] [ratio to stock]
Stock (for diameter comparison)
185/70-13 23.20 100.0%
195/60-14 23.21 100.0%
+1
195/55-15 23.44 100.1%
205/50-15 23.07 99.4%
195/50-15 22.68 97.7%
+2
215/45-16 23.62 101.8%
205/45-16 23.26 100.2%
205/40-16 22.46 96.8%
+3
215/40-17 23.77 102.4%
205/40-17 23.46 101.1%
+4
215/35-18 23.93 103.1%
I do not expect any 19" or larger wheels to fit.
Going to a diameter smaller than stock will slightly improve acceleration at the cost of a small reduction in fuel economy and a speedometer that reads a little higher. The vehicle center of gravity is also lowered slightly with smaller diameter tires. This will tend to slightly improve cornering grip. Obviously the opposite is true for tires with a larger outer diameter.
Maximum size
215 width fits with 45 mm offset wheels
225 width fits with 40 mm offset wheels
195/70R14fits at stock height (outer diameter 24.75 106.6% stock)
This site has a good deal of tire information--some basic some more advanced
http://www.chris-longhurst.com/carbi...yre_bible.html
Bolt pattern
These cars share the 4 x 100 mm bolt pattern that all 86-89 Accord have
The bore size and offset may not be correct though.
Acura
86-01 Integra 14x6
Audi
79-84 4000 14x6
76-84 4000S 13x5.5
79-84 Coupe 14x6
76-84 Fox 13x5.5
? -87 Quatro/80/90 13x5.5
BMW (mid offset)
84-91 318/325 14x6
79-83 320/323 13x5.5
Chevrolet
75-86 Chevette 13x5
86-89 Nova/Spectrum 13x5.5
Dodge
81-86 Aries 13x5.5
84-85 Caravan 14x6
82-86 Charger 2.2 13x5.5
93-94 Colt 13x5.5
82-84 Daytona 14x6
94-96 Neon 14x5.51
78-85 Rampage 14x6
Ford
91-94 Escort LX/Wagon 13x5.5
91-96 Escort GT 15x6
92-97 Escort LX 14x5
97-? Zx2 15x6
Honda
82-89 Accord 13x5
80-96 Civic 13x5
89-91 Civic EX 14x5
86-91 CRX Si 14x6
80-91 CRX/Prelude 13x5.5
92-97 Del Sol V-Tech 14x6
93-97 Del Sol 13x4.5
01-04 Insight 14x5.5
86-91 Prelude Si 14x6
Isuzu
83-89 I-Mark 13x5
87-89 I-Mark Turbo 14x6
83-92 Impulse 14x6
91-93 Stylus 14x6
Kia
00-02 Rio 14x5.5
94-95 Sephia 13x5
Mazda
90-94 323 9 13x5.5
90-00 Miata/MX5 14x6 (most trim levels)
92-96 MX-3 14x6
92-96 MX-3 GS 15x6
90-01 Protege 13x5.5
Mercury
94-? Aspire 13x4.5
91-96 Topaz 13x5
91-96 Tracer 14x5
Mitsubishi
93-96 Mirage 13x4.5
94-97 Mirage 14x5.5
97-? Mirage Coupe 14x5.5
Plymouth
79-90 Horizon/Omni 13x5
81-85 Reliant 13x5
81-85 Voyager 13x5.5
Pontiac
88-93 LeMans 13x5.5
Saturn
91-? S Series 14x6
Suzuki
95-97 Esteem 13x5.5
Toyota
86-91 Celica 13x5.5
88-96 Corolla 13x5
88-97 Corolla 14x5.5
00-03 Echo 13x5
85-89 MR-2 14x6
00-02 MR-2 Spyder 15x6
92-96 Paseo 14x5.5
01-03 Prius 14x5.5
83-97 Tercel 13x4.5
Volkswagen
89-92 Corrado 15x6
85-98 Golf 14x6
81-98 Jetta 14x6
90-97 Passat 14x6
82-89 Quantum 14x6
81-88 Scirocco 16v 14x6
Complied by Bones from:
http://www.discountedwheelwarehouse...._Reference.cfm
Check out what they look like at this page:
http://www.wheelcollision.com/cta.htm
If you have anything to add just post below and I'll make changes as required
If you have a question please start a new thread.
