Shane86
Updates coming soon
Pistons looking good man! Forged?
Unfortunately not their Volkswagen turbo piston 82.75 mm with 21 mm wrist pin
3 Attachment(s)
I did put them on the scale and they weigh exactly the same. Should the valve recesses be on the exhaust side?
Attachment 11202
Attachment 11203
Attachment 11204
1 Attachment(s)
Decrease the block honed the cylinders prepped ready for primer and paint. :flash:
Attachment 11205
Shane86
Attachment 11205
I think that dish in the pistons look like Direct injection pistons. Do you think the compression will come out to low?
Oldblueaccord
I'm really not too worried about the compression coming out low
3 Attachment(s)
3 Attachment(s)
Turbo feed and oil pan prepped. Getting closer and closer
Attachment 11209
Attachment 11210
Attachment 11211
And Copperhead gasket
And here's my YouTube channel if you haven't already subscribed.
https://youtu.be/z3HLrjR_NsA
Shane86
A20 copper head gasket? NAW NAW....when this come out?
Oldblueaccord
You can go to the website and search a20a3 and it's in there you can order them
2 Attachment(s)
Some one with a turbo needs one I cant remember at this point...I didnt think they would make them.
Oldblueaccord
That's was me or t89. The problem we have is the bore size. They didn't make 84mm ones a while ago and a MLS is what I was after.
Sent from my SM-N986U using Tapatalk
Ah ok there you go...understood.
ShiRen
Can't you cut them?
I mean, sure, but I would like my headgasket to be exact if possible[emoji38]. It's not that they didn't make them at one point. Bobafett had a couple made by then, so it's definitely possible.https://uploads.tapatalk-cdn.com/202...c90661fb63.jpghttps://uploads.tapatalk-cdn.com/202...a33d193416.jpg
4 Attachment(s)
1 Attachment(s)
Last one in stock huge shout out and thank you to the sales department at Golden Eagle
Attachment 11218
Damn they look near zero deck!
How did you figure this one out?!!?
Oldblueaccord
Many years of research :D
Shane86
When the grasshopper becomes the master [emoji102]
obd0driver
Lol yes sir
2 Attachment(s)
Part numbers B18 I beam rods. https://www.ebay.com/itm/20400198810...mis&media=COPY
Volkswagen GTI turbo Pistons 2.0 oversized piston. https://www.ebay.com/itm/14242129626...mis&media=COPY
Attachment 11219
Attachment 11220
Pistons did require modification grinding on the inside for the rods to clear
Are these dimensionally the same as an 83mm b series? How come you choose these over a turbo b series piston? Cost? Availability?
