Re: B20A dyno results in!!
Wat?! Where's the results?! Aaahhh!
i somehow feel let down now
What the freak. Fuck us dry why don't ya lmfao. Results now lol
Rendon LX-i
:naughty:
Take a picture and post! Or scan it and change file to jpg :)
Ha ha!! Had to tease you guys first. Videos are being uploaded now:)
First vid is up! Vid came out small because the iphone was turned the wrong way. I will have to resize it later
1988 Honda Accord B20A swap Dyno run 1 - YouTube
2nd run
Dyno run 2 - YouTube
Here is my last run
YouTube
damn my dumb smart phone! ill watch the vids when i get off work today
1 Attachment(s)
^^Alright cool! And here are the results:
you always wanted to dyno a stock b20. so the results 118.4 HP and 117.9tq im assuming that is power to the wheels.
now convert it to OBD1 and tune it. im sure that motor can put out another 10-20hp with a good tune and it will be much funner to drive.
Is that a blacktop? That seems right about spot on! Nice flat torque curve though from 2500 on up! Looks like you could get a little leaner up top, but that would be why you'd wanna tune. Nice safe AFRs from the factory. The HP doesn't look like you got it to the point where it's tapering off though. I wonder if you sourced some gold top or B18 cams what it would do... And I bet if you wound it up to 7000 if you wouldn't show another 10hp or so. Isn't that motor supposed to red line at 7000?
Thanks for posting that! Good stuff!
very nice. some cams would pep her up but then you would need a tune. ME i like speed lol. i would obd1 and cams lol.
Thanks guys! I thought the hp was a bit on the low end. But im at high altitude too. And i have goldtop cams in my blacktop B20a. So does this solve the while 160hp goldtop 145hp blacktop mystery?
Man you guys are all on it. My next step is to definitely fo the obd1 conversion and get some aftermarket cams. I slso want to get my intake manifold ported and track down some headers. They seem so hard to find for the b20a. And 2ndgenguy hit the nail right on the head. On the second graph i was running rich and lean. They told me i should be flat across the 13 mark on the second graph. So she definitely needs a tune.
[QUOTE=2ndGenGuy;1131868]Is that a blacktop? That seems right about spot on! Nice flat torque curve though from 2500 on up! Looks like you could get a little leaner up top, but that would be why you'd wanna tune. Nice safe AFRs from the factory. The HP doesn't look like you got it to the point where it's tapering off though. I wonder if you sourced some gold top or B18 cams what it would do... And I bet if you wound it up to 7000 if you wouldn't show another 10hp or so. Isn't that motor supposed to red line at 7000?
Its at 6500 i believe. And i forgot to take the rev limiter into consideration. I wonder if switching to obd1 will remove it?
That engine has done well then. I remember doing skids with it before i sold it to you haha. That engine is from the same car my digital dash came out of (Y)
Do the OBD1 swap and you can change pretty much anything on the engine. rev limiter etc. Will make more power with a dyno tune also.
AccordB20A
Yeah Aaron. Thats your engine! To me it feels like its making way more power. I bet the obd1 conversion will prove it. I need to pm lxincredible to see if he has any obd1 harnesses left
yeah with a shit tune mine felt fast too but was making like no power.
Do a nice intake manifold like Arron has on his b20. Shunk 2 or blox an a good tb you'll be set
i dont feel so bad now!
105 after spinning a bearing, would like to know what it would have made if it didnt
bullard123
No it doesn't
Also besides a "tune" using obd, there is something wrong with what ya got, as in what's there isn't set right. What has ben recommended for mods so far is spot on, Im not disagreeing with that.
@ Haunted Ca3. Yeah not bad. Is yours pretty much stock?
