Originally Posted by 86AccordLxi
Coilovers probably won't help with your bouncing. Stiffer struts will cure this problem. I don't believe full-bodied coilovers are made for the 3g accord which means you only get the adjustable spring and not the strut that's matched to it (which means you supply your own strut). While it's probable and likely that your bouncing may be due to bad/chopped springs, a lot of the bouncing issue is remedied through struts, so even going to a coilover conversion will not necessarily increase your ride quality.
Alex
