still having trouble
well about a week ago i posted about my car having trouble starting in the morning when i go to work ... it has trouble turning over ... it will eventually start after about 5 min of trying and will run fine after it starts ... also when i leave work the car always starts fine ... i just replaced the battery 2 days ago and it still happened this morning ... what you think ?
I'd check the ground wire from the battery, make sure it's a clean connection on both ends.
Check the ground to the valve cover as well cause that was my problem. But when i had my problem the lights flickered and dimmed. Just to be sure i didnt have the same problem i ran a ground wire to the starter just in case.
ok cool thanks ill check that tomorrow morning
does it crank or nothing at all !
if nothing at all check the starters ground wire ! it's very thin and comes out very easiely ! :(
MIKE
it turns over but slowly .... you know ... errrr er er er.... then after about 3 or 4 min of trying to get it to start it finally will ....then after work it starts fine
Try turning the key but just a step before cranking a few times before really cranking it. Do this a few times, you'll hear the fuel relay click. You might not be getting enough gas. But check the grounds first. Also what's your battery's cca. It's cold outside.
i don't think it's a ground issue as long as it cranks ! do you have a multimeter ( voltmeter ) ?? check the battery voltage when it's sitting !
MIKE
