i was at work and i walked by my car... i saw the brake lights on. so i check everything, their still on. so i unplugged em, and now i dont have brake lights.... anyone know why or how to fix this?????
there is a switch at the end of the pedal. It either went bad, or it just needs to be adjusted.
tim
where at the end of the pedal and how do i adjust it...?
theres suppose to be a plastic grommet that goes on the brake pedal. More than likely it fell out, happens alot. If its still there then you may either need to replace or adjust your brake switch
Heres the breakdown for a stick and an auto the part is number 7 for both the 5 speed and for the auto
http://www.slhondaparts.com/images/PCI/13SE00/009/1.jpg
the same thing happened to me and i ended up needing a new battery from it dying constantly. Follow the brake pedal up the metal bar that holds it. A plastic grommet was missing I replaced mine with a plastic piece meant to hold interior pieces on and some silicon.
same problem here, fixed, thanks for the info
When I had this issue I went to the hardware store and they had rubber stops in the hardware section that were the exact same shape and size as the hard plastic one that broke off.
Haha seems like a common issue. I took my acccord to two shops before they found the issue. They were going through wiring diagrams and testing voltages and everything all to find out it was just a tiny plastic bushing missing.
