Has anyone with a Second Generation Accord found any aftermarket thermostats for other cars that also fit our cars?
Also, which thermostat brands made for our cars does everyone prefer?
They use a fairly standard thermostat. What are you trying to accomplish? I just use ones with the OE recommended temp. I think the last one I got was Stant.
I've also been reading some posts on Prelude Power on lower temp thermostats vs. OEM thermostats and I'm not quite sure that
the lower temp thermostats would be of any benefit.
160 degree thermostat - Honda Prelude Forum : Honda Prelude Forums
The issue that I'm having is that the engine is getting way too hot, and I've noticed that the radiator fan isn't turning
on. I pulled the radiator and fan out and hooked the fan motor up to the battery with jumper wires and the fan motor works
just fine. Tonight when I get home from work I hope there's enough sunlight left to figure out how to test the fan relay
circuits and the relay itself.
Don't do the lower temp thermostat. All the thermostat dictates is the minimum temp, not the max. With the fans, you may have a problem with the temperature switch on the radiator, or the fan relay. The easiest way to find whether the problem is with the temp switch is to unplug it and jump the terminals in the connector. If the fan turns on, replace the switch. Also, the 1985 USDM service manual is here: Honda service manuals - The 3geez Wiki. Go to the Heating & Air Conditioning section and there are procedures for testing the relay (if you have a 82-83, your engine is different, but the procedures should be similar). I would also give the whole system a good flush, take the radiator out, hold it upside-down and flush water through the outlet until you don't see any flakes of anything coming out of the filler neck or inlet.
BTW, when working properly, the cooling systems in these are more than adequate, even in 105-110 temps.
I'll test the temperature switch tonight and let you know what happens. As far as flushing the system goes, the first thing I tried was
draining the old coolant, flushing the entire system, filling the system with new coolant, and bleeding any air in the system hoping it
would be an easy fix. No such luck. Thanks for the responses on this, 2geeSEi.
I tested the relay last night and determined that the relay is good. I had plans to test the temperature switch last night, but ended up
changing the ATF in the '88 Accord instead. Tonight I jumped the temperature switch connector and the fans came to life. I have
another temperature switch laying around in the shop and will use that one tomorrow afternoon. Thanks again, 2geeSEi.
