I Found a web site that sales Se-i Rear Brakes http://www.importedcarparts.com/
well thay have alot of parts for are car's not any thing pimped but new stock parts for cheap
go 2 89-Honda-Accord-Sei-F/I and there you go
you have to use the entire lower arm for the conversion... all i saw in there were things like discs and pads...
Its just an online parts house and they dont seem to be much if any cheaper than the zone or advance/parts america
Does anyone know where I can get a rear disk conversion for my 86 accord?
junkyard, ebay, or watch teh marketplace here... they only came on the SEi in the states, so they are a bit hard to find...
why is this in the appearance forum? shouldn't it be in the suspension or market place?
basically everything in this picure borrowed it from neoblue89lxi
http://memimage.cardomain.net/member...190_1_full.jpg
I was going to place this in that section, but I saw a post that someone started about brakes so I posted my question here.
hey try the 89 acura legend! they look remarkably the same as the sei and the calipers fit from the acura to the sei. i havent tried it but somebody needs to!
a 89 legend bolt pattern is 4x114. That isn't exactly 4x100. I believe someone on this board did it and has the universal 4 lug rims to mask the problem. I can't find the actual thread but it might be on the board still.Quote:
Originally Posted by buds302
Good luck with the rest of it. I don't know about how you are going to get the ebrake cables working but there is a lot of threads made about the 89 legend.
I ALREADY HAVE 4 WHEEL DISC CHUMPS!!!!!!!!
buahahaha
nah j/k looks great for u guys!
i would bet that if need be you can get those e-brake cables new from honda...
Most dual-pattern wheels that fit the 3g are drilled to fit the legend size so if yours are dual patter they will probably work for you. I should look into this since at my local j/y there is a fully loaded legend that looks like the accords sitting there b/c it has a v6 so noone seems to want parts off of it.
These threads might help you.
https://www.3geez.com/showthread.php?t=31951
https://www.3geez.com/showthread.php?t=34994
Originally Posted by Vanilla Sky
around $80 each. fun fun fun.
Damn parts for the rear discs are expensive to be careful. I had a siezed up caliper, Honda wants $400 CDN for one side hahaha.... It ended up costing me a little over $200 CDN at a parts store for both calipers, pads and rotors.Quote:
Then again, I did work at the store so I got just over cost.
