fabrication pics. post you're best and worst moments
I did not realize this part of the fourm was here.... Let's have some fun!
As stated in the title..... lets see what what you got!
Rules:
Lets keep the clowning to a minimum and try to keep it to "constructive criticism".(I know how some of you guys are..)
It must be garage/automotive related.
Example: Diy tools to roll cages, brackets, manifolds, camera holders, stereo kick pannels, amp boards. Just something you had to build .
Ooh! you'r f**kin crazy if i am starting this out!
Re: fabrication pics. post you're best and worst moments
I would post something, but Photobucket has decided to stop working with my computer now.
imagur works pretty good
http://i441.photobucket.com/albums/q...ndaitbs006.jpg
My first attempt at anything flasher than a sub box or a bracket , my itbs and trumpets.
Made the trumpets by turning up a former on the lathe at work and used some 2 inch exhaust tube for the trumpets.
formed the flare by forcing in former into the pipe with a 6 inch bench vice.
some panel steel flanges and she's good.
adaptor manifold is the cut down b20a inlet with a made by me 12mm adaptor plate welded on and machined flat
Heres some pics to keep this on topic:
https://fbcdn-sphotos-e-a.akamaihd.n...e97e4dd7bdb107
https://fbcdn-sphotos-f-a.akamaihd.n...96d4fdb5151df9
Can't wait to get myself a welder next year so I can start fabricating some real stuff!
I actually got a lot done before she went in for this last one, and while she was recovering in the hospital, I was creating wiring diagrams, dash is in, everything tested, it all works, shit ton of wiring back there, I have the tray that fits under the glovebox area done, that holds the MSD and bell crank for the choke cables, I tested the choke mechanism, it all works, all the plastic pieces from the dash back are done and almost ready to reinstall, everything plugs in with molex plugs, so it's easy to remove for the carpet, sunvisors are done, overhead console is done, voice module is installed and tested, and works, getting ready to put in the methanol pump, when I get my tax returns this year, we are going to try to finally get the carbs done. http://i.imgur.com/fbY3eAw.jpg
Ok.
Since we have all that sorted out , and we are on the same page. Can we remove anything not related to the topic. Edit posts or delete them entirely. . Let's keep in mind that i did not mean for this to be another "what are you working on thread".
I don't remember what I was working on but for some reason I needed a small sheet metal brake. So I threw one of these together. Not the best but it did what I needed.http://tapatalk.imageshack.com/v2/14...4a6b6f6274.jpg
http://tapatalk.imageshack.com/v2/14...a46cddfd4a.jpg
So no by has any thing else to share.
I got some but too lazy um busy to get on laptop to upload properly,phone aggrivating.
heres a result on my fresh avatar...functional hood scoop.:D
2oodoor
isnt that the same one I've got but turned around facing forward?
Likely not ^:D its a super rare 88 dodge daytona turbo z hood flipped upside down and used as a fiberglass mold then cut out to fit and made a second mold to press abs liquid plastic into fasteners that match Boeing 707 passenger latrine mirror bezels and screws that came from the actual practice crash site of Evel Knevil's 1st ever failed GC jump...still need to connect the Shelby rear directionals module that will fire up amber #194 bulbs mounted in a section cut out of the dash of a 78 Ford Fairmont. Jk
89T is that a portable gasoline tank on top of the welder ? Kinda like to know where you got that, they use those on some club car vehicles but in 6 gal, that looks more like about 2.5, marine?
2oodoor
friend of mine gave me my hood scoop, I know it's really old, someone had it on the hood of a mustang that he had, and it came from someone else, it's also fiberglass, I had to repair all the mounting points on it
Cool. Yea that's a small marine tank. I got that for my boat at Walmart. I think bass pro has bigger one's.
OMG! Do you really have 88,000 posts?! I feel so inadequate now.
I was a whore before it was cool.
It was a culmination of all post from the different places 3geez has been. While other members started fresh each time the board moved, some of us had the count adjusted to reflect our past numbers. I don't know if it was really 88,000 in total but I did have a lot, I was a very active member Once.
Yamaha Razz Muffler Mod
In keeping with it's Japanese Heritage.
http://i23.photobucket.com/albums/b3...l/IMAG1024.jpg
Muffler Chamber Removed (RIGHT), end cap with 4 holes drilled in it for exhaust (LEFT).
http://i23.photobucket.com/albums/b3...l/IMAG1031.jpg
New shortened muffler, minus chamber/resonator.
Added an ear to the left side that mimicked the shape of the cutout in the bracket on the right.
http://i23.photobucket.com/albums/b3...l/IMAG1038.jpg
HELLO KITTY
http://i23.photobucket.com/albums/b3...l/IMAG1053.jpg
i got a quad with a rotten frame so made it into a gokart
http://i.imgur.com/1g08USm.jpg
http://i.imgur.com/tiZfP1K.jpg
http://i.imgur.com/SS1Ie8W.jpg
ideally i would like to convert the steering to rack & pinion cause it's way too heavy
