Will a h22 intake manifold fit on a b18 ?
I believe you needed port matching to get the h22 to work on a B20A, i dont know about the B18A. also not sure if it was exhaust or intake that was mentioned. Searches came up empty, a lot of broken image links.
Dose anyone else know if an h22 intake manifold would work on an b18
It will not work on a B18A
The only aftermarket intake manifold would be the B16 manifold or the Type R manifold from the B series(vtec). The H22 headers fit the b20 but will need custom downpipe because the angle is different.
Never heard of a H22 intake manifold on a b series.( its a dual stage manifold like the GSR and A20) not worth the swap. Most people that have H22 use the K series manifold with special adapter plates
