what is the best option to swap engine in my 1987 honda accord currently it has A18a, i need a bolt on suggestion
B20A will drop right in. But you need to convert to fuel injection, which is not necessarily bolt in.
does B20a needs mount and axles adjustments?
I presume it would just be a larger bore and stroke and probably the same block casting. It would be cool to see a A20 bottom end and some A18 side draft carbs on a build.
I was thinking about doing a b20a with transmission. Is there a site were I can just find the complete swap in a kit. If not could someone please be so kind as to help me out to were I should look on this site. Sorry I am new to the 3rd gen world came from the 4th gen.
hahahaha. search.
