Re: Distributor housing seal
So quick update. You remove the dizzy, thermostat, any thermo sensor vacuum hoses and what not. The housing comes off, it has a water passage gasket behind the thermostat and an O-ring in the housing for the end of the cam. My O-ring was harder than granite and super brittle. Soo replaced them, autozone still caries the water gasket, I went to a hardware store for the oring. Replacing the radiator at the same time and started flushing the A/C system. Should have everything back together soon and ill report back vent temps with R152a.
R152. That's the canned air from Wal-Mart, right? It should work out pretty well. Keep us posted.
