6 Attachment(s)
Starting to work on the interior got a lot of work to do
4 Attachment(s)
2 Attachment(s)
Carpet installed not the best job but it's a lot better than no carpet. Will have better pictures tomorrow
8 Attachment(s)
Tdurr
Where the pics at?
carpet seat covers and floor mats
i really hope your car is not upsidedown
Im sure it just makes installation a breeze!
Ryon Toth
Lol yes I'm going to use this technique when I install the headliner
2 Attachment(s)
My hood latch quit working so I decided to go ahead and put inn the hood pins. Best place for me to install it directly on the radiator support.
hey look the pics arnt upside down! like the progress man! when do you think you will get to drive the car?
Tdurr
the car is up and running I've actually went a 136 miles so far . after removing the EGR valve and majority of the black box components I no longer have code 12.. and it's a lot easier to adjust the idle. and for the stage 2 plus spec clutch I like it I was expecting it to be more aggressive but it feels pretty good. everything's running pretty good right now
That's great man! Get some videos & get a tune!
Edit: i see ur not boosted yet, idk I thought u were lol. Also the clucth pedal shouldn't be that much harder and oem.
Tdurr
Yeah I still have to convert to OBD1. I still don't have a job so I'm kind of at a standstill with it.
Tdurr
Ahh that sucks man.
It's all good .I'm going to continue to enjoy the car and work on my OBD1 conversion
Like ur mindset. Just keep tinkering
5 Attachment(s)
300 miles the rrod ecu took a crap.luckily i had a backup one. took the plug from the old ECU and got an OBD1 connector and a little shielded wire going to try do it yourself conversion harness
brave man. I use the ebay harness. its like 20bucks and easier to re-pin then all that work to make your own.
Tdurr
Yes sir i think this is something i need to learn
2 Attachment(s)
I Threw the towel in on the jumper harness too much of a nightmare :banghead:
U can spend 20-30 on a eBay one & use the how to guide to do it. Or you could pick up a boomslang one for like 100-140 & its plug & play
Tdurr
That's the plan to go with the eBay one I got plenty of practice repining the past 2 days. does your wideband hook into the jumper harness?
yup on the one that i have there is a separate harness for additional plugs, like o2/wideband imput, cel light grn, ect. they are just spliced into the proper plug tho.
