Donnyten
I have an 88 accord Lxii. It was given to me for $350 but Ive yet to finish the other half of payment. It has 278000 miles on it and a pretty bad oil leak which appears to be coming from that oil rubber hose on the lower back of engine. It's running off and dropping on to the exhaust pipe causing intermittent smoke. The AC and radio does not work.It also has an issue where it vibrates violently when started until it warms up. The speedometer is also wonky as well. Aside from outside rust on the exterior car is otherwise robust. However all vacuum lines look old, some components in the Bay rusted, Unsure of when the timing belt was changed, Or any of the belts for that matter, Not even really sure if the oil leak is coming from that hose but can see dripping from the lower end of part. The icing on the cake would be if the rear main seal was leaking as well.
I am pretty handy when it comes to repairs but I'm not sure if this car Is worth the hassle but a little torn because otherwise It drives fine.
Someone was selling a 2004 Chrysler vehicle for 1500 with 170000 miles that currently has a check engine light. I've yet to see what the code is but im debating on if I should just get this vehicle and work on it as opposed to maintaining a 20 plus year old car.
I've been told that nothing is wrong with the Chrysler as it's coming from My brother's friend And was driven by his stepmother who's getting a new car soon. Just want your thoughts on this as my current state of employment is not guaranteed beyond the end of June as a contractor With no savings and want the best opinion
