Primary Cutoff Solenoid Valve and idle Issue
When i took out my carb to clean replace gaskets, i noticed that my primary cutoff solenoid valve had a wire running off of it, but it's disconnected. I think i found the home for the wires but i need some guidance.
Also, when i start up my car when warm, she idles at like 2.5k and doesn't wanna go down unless i pull up my throttle with my toe. She's been getting better at not wanting to go so high so quick but does anyone else have this issue?
Tomorrow ill get a video of start up and the Primary Cutoff Solenoid Valve Wire and where i think the wire goes.
200$ car i gotta make last and engine problems are even the worst of it :) :ugh:
Re: Primary Cutoff Solenoid Valve and idle Issue
If the cut-off solenoid is unplugged, the car wouldn't idle at all. I bet it's been cut inside or something.
