The temp gauge on the dash is barely 1/4 way up even when going 80 mph on the highway(car also starts shaking at 85, probably need to get it aligned and balanced and checked, 10 yr old tires lol. Speedo also ahead 3-4ish mph). Also ive noticed that as the air temp goes colder the needle also gets lower so the sensor should be working. So is it the sensor's fault or the needle is broken? should I be worried?
The second issue is that it looks like something exploded/squirted out right behind the engine onto the frames. Its this weird green/light green goo but like I drove it around again I noticed it and it has not changed(no more new goo). Is it like coagulated coolant? idk looks weird. I did a recent oil change and the oil was normal looking. Refilled the coolant prior and the level is still the same.
This car got alotta minor issues.
