Discontinued or hard to find 3gen parts list...possible replacements.
Wanted to start a list of the discontinued or hard to find parts.
A few I had in no particular order:
1. Power steering reservoir /filter. Honda Part No.: 53701-SE0-953
2. Trans speed sensor. Honda Part No.: 56500-PH1-040
3. Brake proportioning valve. Disc/drum combo.Honda Part No.: 46210-SB6-013 replaced by 46210-SE0-A02
4. Coolant pipe A20. Honda Part No.: 19505-PJ0-A00
5. Thermostat housing. Honda Part No.: 19320-PJ0-661
6.86-87 LXi Front Engine Mount Honda Part No: 50810-SE0-932
Re: Discontinued or hard to find 3gen parts list...possible replacements.
I'll add this one:
86-87 LXi Front Engine Mount (discontinued). Carb engine mount still available.
Edit: Honda part number - >> 50810-SE0-932
if you could find the correct Honda part number Ill add it....also look up the coolant pipe too while your there ..Thanks!
Oldblueaccord
I believe you are talking about the one that connects to the water pump ->> 19505-PJ0-660 (LXi)
p.s. I edited my original post to include the part number for the front mount.
Thank you!
I like when people double check my work!
AC439
I'll add this one:
Looks like the engine mount for the '86 LX is part number 50810-SE0-930, but I can't find it available anywhere. Any tips on where to find an OEM unit?
Give up on buying OEM and get whatever they have on rockauto
Why is the LXi mount on the list? It's the same mount.
The part numbers are different. The LX mount is 50810-SE0-930, but the LX-i mount is 50810-SE0-932. Both are front mounts.
They're not a different mount. 932 supercedes 930. They both support the exact same engine in the exact same car
::Edit::
I believe there are actually 3 different front mounts for the 3gee. The height is the difference, installing the wrong one will fit but your engine will not sit right.
- Automatic Carb and FI are the same (50810-SE0-932) (Replaces 50810-SE0-930, 50810-SE0-931)
- 5Speed Carb
- 5Speed FI (50810-SE0-J31) (Replaces 50810-SE0-J30)
Also to note. The aftermarket mounts never knew there were different mounts so just because it says its for your car doesn't mean its right.
I'm curious as to how much of a difference there is. I have a GM trans mount as my front mount
ShiRen
The carb mounts shorter or the mounts available are to tall.
Any whoo any one mind if I spin this on off to its on thread?
