How-To: Removing/Installing Stock Radio
Here are instructions on how to remove the stock radio out of our cars.
http://ultimatuner.com/hosting/blood...ssassembly.JPG
(*NOTE*) There are two common situations of headunit installation. Most common is the 1-Shaft which is pictured here:
http://ultimatuner.com/hosting/blood...eassembly1.JPG
Then there is a 2-Shaft installation
http://ultimatuner.com/hosting/blood...reassembly.JPG
Hope this was helpful.
Re: How-To: Removing/Installing Stock Radio
not to burst anyone's bubble but the pics are dead.
can someone get new pics up or reupload them?
Yeah please, I'm working on taking out the stock radio and your pics are gone...so please put them back or direct us to the right place...
thanks...
there are two screws behind the factory radio that need to be removed before sliding the radio out, you can reach back there with a stubby phillips screwdriver.
Here are two pics of the rear of the radio where the screw are at
http://img.photobucket.com/albums/v3...p/DSC00025.jpg
http://img.photobucket.com/albums/v3...p/DSC00026.jpg
Once you you slid the radio out just unplug the harness and antenna cable
OMG my shop guide LIES! Thanks again 3geez
I take it this doesn't apply to the SE-i bose setup? Do I still need to remove the center console for mine?
they should be mounted the same.....
nfs480
The Stereo should be mounted the same way as shown but I know it plugs into a small amp, which i know nothing about
the small amp should be mounted in the trunk under the rear deck at lest thats were it was mounted on the SEI coupe
Hi guys
Am I being stupid, or have the instructions gone?
whufc
Hi guys
nope there not there.
just remove the 2 phillips screws on the back of the radio and it will pull right out.
Thanks for your reply Pico.
I was wondering if it was slightly more involved than that. My problem is, I can feel the screw on the drivers side, but can't seem to gain access to the screw on the passenger side, and I was hoping not to remove any other bits and pieces.
I'll try again, and if I never post again, you'll know my hand is stuck behind the dashboard https://www.3geez.com/forum/images/icons/icon12.gif
i find its easier to unbolt the little grey box to get more access to the back of the radio
stubby screw driver works the best as well
you can also use an 8mm socket i believe
lol on one accord i was working on, some ass nut went and put a stupid aftermarket tape player in and put rivets where the screws would normally go :facepalm:
Hey guys, new to the forum. Just got an 89 SEI and found out the stock wiring harness for the radio was thrown out when an aftermarket radio was put in :( Came here to ask if anyone new the color codes on the wires and found them on link posted by HostileJava. Found exactly what I was looking for. Thanks. Does anyone know where i can get a replacement stock harness???? If anyone knows, hook me up.
j/y if you can find a sei
are you planing on staying after market if not you may need the stock bose amp the stock speakers im not sure if after market ones work on them
