Are there any transmissions that bolt directly to the A20A?
Other than the A20A transmission, obviously...
My tranny is pretty beat, and I'm wondering if there are any others that might be able to take it's place. Something that has a quality aftermarket LSD available would be great!
I'm looking to go turbo, so even a tranny with long gears would be good. Probably better, in fact.
Re: Are there any transmissions that bolt directly to the A20A?
86 Accord lxi hatch with jmba7 badge here, so do i have a bt engine same as 1986 prelude si?
All hub splines and tranny splines, and cv axle lengths are the same for every 3geez? accord, and prelude? I worry. I need to swap my transmission 5spd too and Id love to use a prelude 5spd but is that front end width the same? Cv axles from my accord going to fit or do I need axles for the prelude car and will those fit into my accord wheel hubs?
Pretty sure it's the same, but I would worry about trying to find that trans instead because good luck with that
Verify the splines fit the diff and use the accord axles, the trans case is the same so it would fit the same otherwise
ShiRen
Yeah find one is hard there's a lude sitting in a yard near me but I've been hesitant to grab it as is no use to me after A to B plate but I figured somebody might want it I just don't want to sit on it forever. And you're correct the Prelude axles and spines are the same as the Accord it is a direct Plug and Play bolt in matter of fact you could still use your Accord axles in the Prelude transmission or vice versa. I've also found out which isn't new that B series axles will fit the 88 and 89 Accord hubs same with those that B series swap they're running one Accord and one B series axle whether it's an Integra or CRV.
Sent from my SM-N986U using Tapatalk
