polishing your distributer would make that looks sick nastyQuote:
Thanks for the positive comments guys they keep me goin!
Heres the latest progress:
Sprayed a bunch of coats, must be like 4-5 pretty much emptied the can. This is after baking.
http://i9.photobucket.com/albums/a69..._cato/vc01.jpg
Sanded the high stuff and some clear coats down.
http://i9.photobucket.com/albums/a69..._cato/vc02.jpg
Can you say Gold Top A20A3 haha:cheers:
This is where I had some crazy turnout, as I was baking the top coat the smell started to get stronger(there is some when you initially bake it, its less strong if you let it dry overnight) and so I whipped it out asap and turns out I somewhat burned it I guess... but looking at it now I like it a lot haha!!
http://i9.photobucket.com/albums/a69..._cato/vc03.jpg
http://i9.photobucket.com/albums/a69..._cato/vc05.jpg
Cut a test hole in the cover, I might make it a little bigger so I can see the degrees.
http://i9.photobucket.com/albums/a69..._cato/vc04.jpg
http://i9.photobucket.com/albums/a69..._cato/vc07.jpg
It's not perfect but hey for my first one I think it turned out pretty damn good! You live and learn..
Thanks for the reply carotman, I will have to look into the tank thing. I haven't been able to get the fuel pump out due to the nuts being rusted and just stripping.. I will look into the matching harness problem too.
Also what about all the stuff that wont be hooked up question?
