Re: B20A stock ROM on OBD1
I've been trying to find this for a long time.
Uberdata and Crome and others can't import the obd0 maps for the PH3 ECU properly.
I've been trying to even OPEN the ph3 maps properly so I can throw them in a .bin file, but have been unsuccessful.
I'm basically using a GSR/LS hybrid fuel/ignition map setup on my b20a, and we've adjusted fuel big time to make 13:1 a/f's at WOT all the way through the RPM band. But I feel like a fresh PH3/b20a map would be a much better base.
I had one built and if I can find someone to load my chip into an email file you can use it. Its basically a simulated rom, not tuned. Its very close for my build but mine isnt stock. Ive got larger intake, exhaust, cams, ignition but if you know how to import it Ill try
I burn my ROMs right onto my own chip.
The .bin file that it gets burned from - that's all I need.
Something that will import into an obd1 burning program to burn onto a chip. If there is a 'chip' like it, the ROM definitely exists somewhere!
i don't really know what you're talking about, but there is a ph3 .bin file here if it's any use to you http://www.ilostmymind.com/ECU/HONDA...-88-Accord.bin
http://www.ilostmymind.com/ECU/HONDA/
That makes sense versanick but mine was loaded for me. I suppose I could bring my laptop out to my car and extract the .bin file from the ecu if I knew how. Do I just plug my ecu via usb into the laptop and open the program used to create the file or do I need some other equipment
I have a copy of thegreatdane's OBD1 ROM for his B20A at home.
I'll host it when I get home.
carotman
Carotman,
you're the man.
Do you mean host it on your web page?
carotman
We were thinking that using LS ignition maps, although not too far off at high RPM, the low and midrange aren't even close because of the completely different stroke on the b20a.
I was looking around to see if sites that sell Stroker kits for the b18 might have stock maps that they give people, but I've sent a few emails out with no luck.
So a b20a ANYTHING obd1 map will be a boon.
Isn't there a b21a1 obd1 ecU?
