Results 1 to 3 of 3
Thread: What Engine Can Fit Into My 89 Accord Lx Without Having Any Problems...
    WHAT ENGINE CAN FIT INTO MY 89 ACCORD LX WITHOUT HAVING ANY PROBLEMS...LIKE HAVING TO CHANGE THE TRANNY CAUS ERTHE ENGINE DOENT FIT RIHT NTO IT. AN I WANTTO KEEP MY CARB. AND ASO THE MONEY AINT TOO GOOD SO IF POSSIBLE SM CHEAPER IDEAS . THANKZ
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    I think the lack of replies is due to the fact that you could answer your questions by using the search function...
    The B20A is the best swap... especialy if you want to keep the stock carb or swap later on to a better carb set-up.
    don't expect much power because the stack carb wasn't ment to sit on the B20... or so I suspect.
    no swap is cheap... unless you get lucky.
    LX User 89LXiCoupe's Avatar
    1989 LX-i Coupe
    California
    Re: What Engine Can Fit Into My 89 Accord Lx Without Having Any Problems...
    Cheap? I'd say stick with the original A20A1. You'll only need a cherry picker and some time on your hands with the assumption that you have the tools.
    "Please don't hesitate to use full throttle."
  1. [Help]Having Engine problems with an 81 accord.
    By Hondaccord82 in forum 1geez Tech & Performance
    Last Post: 08-27-2009, 07:19 PM
  2. Engine Problems..
    By Francos Accord in forum 3geez Accords
    Last Post: 04-10-2009, 01:17 PM
  3. 86 Honda Accord Dx Having Engine Problems.
    By stillhoopin22 in forum Carburetor Tech
    Last Post: 03-29-2006, 01:11 AM
  4. 1988 honda accord engine problems
    By MaTt16289 in forum Carburetor Tech
    Last Post: 03-17-2006, 12:58 AM
  5. engine problems
    By idriveahonda in forum 3geez Accords
    Last Post: 11-10-2002, 11:14 AM
