can someone please post a how to change fuel filter.....i want to change mine but i dont know where it is ....thanks guys...
89 accord LX-i , may she rest in peace
7/1989 build date
6/2000-4/2003 135624 Miles
:bh::pimp:
4/03-11/04 94 Saturn Sl2
11/04-03/14 2001 Hyundai Tiburon
3/14- now 2014 Dodge Dart SE
The need for speed is never satisfyed
really really simple!!
on Carbed modeals theres 2 filters on by the gas tank and one by the carb
saem for the FI models but none up by the carb
first thin ggo get borth a primary adn a secondary filter from teh parts store one will be plastic and teh other metal(plastic is primary one)
jack the rear drivers wheel in teh air so you can slide under teh car and USE a jack stand to support teh car not just teh jack
beside the gastank there somewheres there should be a thing that looks just like the filter you picked up...
depending on how many times your filter hass been changed means what type of fittngas will be connecting it...
undo the fittings and slide them back......carfeul here you may loose some gas so you should get somethign to block the inlet side hose off while you replace teh filter
just pop it in both sides and tighten up th efittings and voila your done
drop the car back on teh ground(and check for leaks and such on the primary one....
now pop the hood adn on teh drivers side of the carb you will likely see a "red" braided hose goign to the carb adn in this line there will eb a thing that looks like the primary filter you picked up....
it should have clamps or fittings on either side of it remove these adn slide them back remove old and install the new.
Remember each filter has arows on them to point to the front of the vecehle make sure you don't put them in back wwards
good luck
nothing
don't EFI cars have only one filter in the engine bay !?
MIKE
yea its on the fire wall passenger side its a big filter
hmm and you thought the reverse polarity of the sun made you loose to a 3rd gen accord
can anyone post a pics...i have a general idea of where they are now but im a visual learner...plus we could compose this into a how to for the HOW TO Section..thanks1:p
me
my car
and then sometimes i feel like when i work on my car
7/1989 build date
:bh::pimp:
I bought a replacement fuel filter, but it's the only thing I didn't install yet.
The fuel filter is down much lower on the firewall than I expected... seems like I might have to remove some stuff to get clear access.
Fuel injected cars usually have a "sock" filter over the fuel pump inlet in the fuel tank. So technically there is two filters
2003 Element Sunset Orange
2002 S2000 Spa Yellow
1999 CRV EX 4WD Auto White
TRADED: 1988 Accord LXi Sedan Auto White/Maroon
Had: 01 Civic EX Coupe, 00 3.2TL, 95 Integra GS-R Coupe, 92 Civic EX Sedan, 88 Legend Coupe LS, 88 CRX Si
actually so do teh carbed ones....so that would be 3 for them...lol
if you car has clogged filters you might test you fuel pump too depending on how long the lines have been clogged up....
nothing
I just changed mine and it wasn't all that hard. You don't have to move anything just pull the filter out of it's "cup holder" and manuver it towards you so you can get better access. I used two adjustable wrenches to take off the sending/reciving lines and put it back in reverse. Also change the little metal o-rings.
That's why I go aftermarket on the fuel filters. The aftermarket ones come with a complete set of new copper washers. I used open ended wrenches rather than adjustable. To loosen the odd shaped "banjo" bolt it is definitely much easier to pull the filter out of its bracket first.
Be sure to loosen your gas cap and remove the small pressure relief bolt on the fuel filter first to prevent spraying gas everywhere. I got sprayed in the eyes with gas one time changing a fuel filter and it DOES NOT feel good at all.
Later.
once i get my conputer back ! i'll do a how to on it !
MIKE
I took off my fuel pump and filter and I had to lower the gas tank and take down and move all kinds of things. It took over 5 hours to complete because the stupid fuel pump someone super glue the damn thing to the gas tank its self, can you believe it. I guess its only my car that needs all that special effert to get to though.
I replaced the Filter on my 89 Lxi, and the OEM filter I had ordered from Hparts.com came with all the needed washers. I used to use Fram filters for air, fuel and oil, but recently i changed over to all genuine Honda filters. I noticed a difference especially with the Honda air filter, just a thought.
when i replaced my fiter, a week ago, the idle wenbt up to 1800 rpms at idle, just a little cloggage in there. must have been why my cold idle didnt boost it as much as it should.
peace
fussell
how did you fix your idle ?
7/1989 build date
:bh::pimp:
Those f#%in canister filters are a real pain in the ass!!!!!
Just to warn you guys. I would recommend a little WD40 on those Zebart and rusted bolts before you put the socket up in there.
Also, wear some safty glasses cause all that shit's gonna come down on your face and inta your hair (got a buzz cut afterwards ) get ready for a little gas in your face 2.
Need a lot of patience.
Good Luck
-Mike
Mike's Clean Cnd A20A2 5 spd Champaigne Beige Sedan Accord, Eh!
B-Day: 07/87 in Alliston, ON Canada
The best mods are mods that can be modded over and over again.
don't break the input line to it either.... mine snapped cuz it was on way too tight by whoever changed it last, and when the bolt turned the whole thing moved and tore my fuel line .... $75 for that small ass line
Mods thus far:
94-00 GSR intake pipe
Custom ground cam
Custom Catback
Matrix springs w/ tokico blues
17"American Racing estrellas
Tinted windows
Clear Bumper Lenses
2 1/4" Catback exhaust w/ OBX muffler
just bringin this post back to everyone's attention. I really need to change my fuel filters and was wanting to know if anyone was still planning on doing a how-to with pictures. that would help a lot. I read the other replies but still not sure where the filters are at. I have an FI model. I already found the filter that is on the passengers side on the firewall, but isn't there another? thanks
"Turn off the television sets and eradicate the slander that says a black youth with a book is acting white." - Barack Obama
thats the only one on an FI i believe, its not all that hard to change..... providing lines don't break
Mods thus far:
Custom ground cam
Custom Catback
Tinted windows
Clear Bumper Lenses
FI cars definitely only have filter to change. Relieve pressure (12 mm?), remove both bolts (used cresent wrench), loosen mount (10 mm?) bolt. Replace filter and reassemble. The FRAM filter I got came with copper washers that were too thin. Once my fuel pump started it would drip fuel everywhere and the engine wouldn't start. But it worked fine once I put the old alumunium ones back on. Sorry, no digital camera, so no how-to from me.
Mike
Say what?? Who the hell charged you that!?
Eric
thanks 89LXi4dr, that should help a lot. someone mentioned wear safety glasses b/c the gas will come down in ur face. I thought this was all done from above?? oh well, i think that was for a carbed model.
Safety glasses are always a good idea if you're not sure, but I didn't get any fuel in my face. It just made a small puddle. Be sure to work in an open space. Gasoline vapor is no good.
Mike
did u change it from above or below?
hey its done...all you have to do is take the input line and output like that goes on the fuel rail off and its a snap..took me 20 min...carotman helped alot also
7/1989 build date
:bh::pimp:
I changed in from the top. It would be really difficult to work from underneath since all the fittings are on the top of the filter.
Mike
