Results 1 to 5 of 5
Thread: Very little spark from coil
    Jun 2014
    88 Accord LXi
    The other day I was driving and suddenly my car just shut off. The engine turns over but refuses to start. First thing I did was check for spark and found that the coil was firing only once and with a dim orange spark. This is the list so far of what I've done for troubleshooting and what I've replaced with new parts.
    The coil is getting 12v.
    Replaced coil with new.
    Replaced all spark plug wires including coil to distributor wire with new.
    Replaced ICM with new.
    The car is an 88 Accord LXi.
    Re: Very little spark from coil
    Quote Originally Posted by Float On View Post
    The visual check for spark is not all that accurite. I would look at your cap and rotor since the spark travels thru there. There pretty cheap. Also may look at your timing belt. It turns the cam and the distributor runs off the cam.
    conozo's Avatar
    Fort Wayne, Indiana
    Fuel Pump?
    1988 Honda Accord LSDX-I
    Jun 2014
    88 Accord LXi
    Never even crossed my mind to check the timing belt. Just had it changed about 50k miles ago. Its broken. Anyone know if its a non-inference motor?
    LX User niles's Avatar
    Oct 2009
    87 LXi Hatch
    Non-interference it is. However after you install the new belt, you'll want to manually turn the crank pulley a few times to make sure nothing is messed up.
  1. Help! No spark at coil
    By senor honda in forum 3geez Accords
    Last Post: 01-22-2011, 08:23 AM
  2. No spark after Coil repclacement
    By DX87 in forum 3geez Accords
    Last Post: 07-07-2007, 06:29 AM
  3. full bodied coil overs vs coil over sleeves
    By newaccorddriver in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-19-2007, 11:54 AM
  4. full bodied coil overs vs coil over sleeves
    By newaccorddriver in forum Classic Honda Community Chat
    Last Post: 06-17-2007, 11:57 PM
  5. coil has no spark???
    By military mase in forum 3geez Accords
    Last Post: 01-09-2006, 03:00 PM
