Results 1 to 8 of 8
Thread: oxygen sensors
    LX User 88LXI's Avatar
    71 ford pinto
    boise, Idaho
    Unhappy oxygen sensors
    im doin a b20a swap and i want to use the exhaust manifold that came with the engine because i can make it fit easier than the prelude one... my question is how do i switch my car from 2 O2 sensors to one?? do i have to change the ecu to the earlier one for the 86-87 accord? or is there a way to do it with my current setup?
    Jun 2001
    88 lxi coupe
    gainesville, fl
    I dunno..just use one? And another dummy. Maybe
    yeah you have to use the 86-87 computer or you will have the check engine light on all the time (sucks)
    1988starter
    Guest
    If you are going the on O2m sensor root and insist on using the 86-87 ecu instead use the 84-87 lude Si ecu it works much better
    10/Honda/Ridgeline
    NJ
    for some weird reason i am running on onej O2 sensor and the green one is left out, and still i got no codes.
    3Geez Veteran Coroncho80's Avatar
    Philly
    Does anybody knows which one is the oxygen sensor A? I gotta change mine ( check engine light on and i hate it!) and the computer says oxygen sensor A. does anybody knows?
    Maurice
    May 2009
    Re: oxygen sensors
    Hola
    Tengo un Accord 1988, y necesito cambiar los sensores de oxigeno. Hay algún reemplazo equivalente a los originales. Éstos son de un cable y sus terminales son blanco y verde.
    I have a 1988 Accord, and need to change the oxygen sensors. Is there any equivalent to the original replacement. Here they are a cable and terminals are white and green.
    Atento a sus comentarios.
    Re: oxygen sensors
    Si, hay equivalentes. En caul pais este usted?
  1. 2 Oxygen Sensors
    By vince in forum 3geez Accords
    Last Post: 07-29-2006, 08:53 AM
  2. exhaust manifold oxygen sensors
    By evans 86prelude in forum 3geez Accords
    Last Post: 04-25-2004, 02:42 PM
  3. oxygen sensors
    By adams86lxi in forum Classic Honda Community Chat
    Last Post: 12-26-2003, 11:46 PM
  4. Oxygen Sensors
    By Janiel in forum 3geez Accords
    Last Post: 06-12-2003, 11:27 AM
  5. Oxygen sensors
    By MiGRaNe in forum 3geez Accords
    Last Post: 05-23-2002, 02:06 PM
