Results 1 to 25 of 31
Thread: Prelude SI 2.0
    DX User Zeboy's Avatar
    Nov 2002
    '89 Accord DX
    Levittown, NY
    Question Prelude SI 2.0
    I have recently found a 1986 HONDA PRELUDE SI 2.0 LITER WITH A 5 SPEED TRANSMISSION. The only thing thats wrong with it is that it hit a curb and than smashed onto another curb and broke the front axel. The engine runs fine and thats what I am really interested in. Anyone that would know whether or not the engine in this would fit in my 1989 accord would be greatly appreciated. Thanks.
    Here is a link to the Prelude pics
    Nov 2002
    '89 Accord DX
    Levittown, NY
    It has a carb A20A1 motor. ---To help you answer my question---
    LXi User Nospeed's Avatar
    Oct 2002
    87 busted ass hatch
    Salem, OR
    From what i understand, yeah, it will fit. my 88 dx has an a1 in it too, so you could probably just plop that engine into it with no probs...correct me if im wrong.
    - Justin
    carotman's Avatar
    Montreal South Shore
    It's not a carb if it's an SI model.
    but yes it will fit your car if you take the hardware from your current DX engine (carb and wires and some other small stuff)
    I need these parts!
    Nov 2002
    '89 Accord DX
    Levittown, NY
    what do you mean "if you take the hardware from your current DX engine (carb and wires and some other small stuff)"??
    LX User flamed89's Avatar
    89 accord LX-i 88 accord lx 93 teg 4-dr
    maryland
    yea he's right,i have an 86 si. it has the same motor as the 86-87 lxi. if you buy the car let me know i might be interested in some body parts!
    Nov 2002
    '89 Accord DX
    Levittown, NY
    I hear that the engine will fit, but don't prelude engine sit towards the firewall and accords sit towards front. How would it work if they are opposite?
    maryland
    dude i realy think that the engine bays are pretty much identical. the motor and trans are exactly the same as an accord. oh and carot means you will have to put the carb intake and other part on the si block for it to work in you car,unless you do an efi conversion!
    Nov 2002
    '89 Accord DX
    Levittown, NY
    Nice... Cause My friends are saying that I wont be able to do it.
    89 coupe/ 06 TL 6spd
    Vancity
    why would you want to put that engine in your accord??
    the a20 in your 89 is better then the a20 in the 86 lude...
    it's not wort it...the accord engine has more HP and TQ then the 86 lude...you would be losing if you did that swap..
    plus, i can eat those ludes alive in my accord...
    R.I.P Spoon Se-i 01/17/04
    carotman's Avatar
    That's NOT true
    Doublecheck your info before posting attrocities like this one. The Lude engine is better than the Accord engine. Wilder cam, different cam sprocket, different distributor. better transmission.. Lots of small stuff that make the lude better.
    I need these parts!
    PhydeauX's Avatar
    Eastern Penna
    Didn't know the cam sprocket was diferent. Is the cam timing slightly diferent on it. My have to try that untill justin gets around to getting those gears finished, or I just have my own made.
    andy
    Vancity
    ok.. well my point is..
    why would he put an 86 motor... is his 89????
    that makes no sence...
    also.. it is carbed...so it's not that great!!
    just like the 3geez.. auto and carb are the slowest you can have.. those ludes are the same... auto and carb = slow!!!
    I have easily beaten sooooooo many of those ludes...
    YK86's Avatar
    Oct 2000
    BC, Canada
    That's because the 86/87 Prelude 2.0SI has the 110HP BT/A20A3 EFI motor. His 89 has the 98HP a20a1 carbed motor. If he had the 89 A20A3, that's a different story.
    Also, I did alot of part number checking and from what I can find, the Prelude motor uses the same camshaft as the Accord (part number 14111-PJ0-010 for the 5 speed). I checked this because I wanted to know if the Lude cam would be a good core for regrinding. The cam gear was also identical when I compared it to the Accord ones I grabbed.
    As for the Lude engine that doesn't fit, you are thinking of the 88+ B20A5 motors that til the wrong way and stuff.
    www.b20accord.com
    Vancity
    Don't the carbed 88-89's have 110hp??
    and the carbed 86-87's had 98 hp??
    and the EFI 88-89's had 122 hp
    and the EFI 86-87's had 110hp???
    thats what I always thought....
    Nov 2002
    '89 Accord DX
    Levittown, NY
    ok. I have a carbed 5 speed and the lude is a carbed 5 speed. My engine is shot. There is something worng with it and I haven't had time to get it fixed. When I got it the guy said the piston rings went, then it was the head gasket, than it was the timing belt. So stead of paying so much to get the pistons fixed. I figure I'll get the whole car for cheap and take the pieces I need.
    So, it's either a working engine or non-working engine.
    Nov 2002
    '89 Accord DX
    Levittown, NY
    I appreciate all the replys everyone has posted. It has helped a great deal.
    YK86's Avatar
    Oct 2000
    BC, Canada
    If the Lude is carbed, it's not an 2.0Si.
    www.b20accord.com
    Nov 2002
    '89 Accord DX
    Levittown, NY
    Oh. Then my bad. I wrote the wrong thing then.
    SEi User
    Jul 2002
    '89 Accord LXi Coupe w/Sunroof
    Santa Clarita, CA
    so yasu does this mean that i can pull prelude shafts as well as accord shafts. since you say that they are the same.
    ACT Stage 1, Short Ram Intake & 2.25 Dynomax custom catback w/4inch carbon fiber tip. Thats it for now.
    Putting the paint back on after
    SOMEONE STOLE MY PAINT!!!!!
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    this is what u have if it is carbed... a A18... with a tranny that is different than the accord... the whole engine may fit, but maybe not... i know the 2.0 SI will go in... it is identical to the 86-87 LXi. i have a lude EFI A20. i am converting it to carb...
    Travis
    PhydeauX's Avatar
    Eastern Penna
    The a18 will swap in. I think it came in some of the overseas accords. The either tranny will work on the motor. It depends which car you are swaping into which tranny you need. If the car had a 1.8 then you need the 1.8 tranny. If it had a 2.0 then you need a 2.0 tranny. It only has to do with the axles.
    andy
    YK86's Avatar
    Oct 2000
    BC, Canada
    I'm pretty sure after looking at them side by side and also looking up part numbers.
    www.b20accord.com
    2.0Si User buzzbomber88lx's Avatar
    1985 Toyota Celica GT, 86 accord lx-i, 89 supra turbo
    Kansas
    Why does my pops' 90 prelude have a 2.1 in it? Is it because it is the si 4ws or did that motor com in any of the other models?
    1985 toyota celica 3sgte project
    1989 toyota supra turbo
    1986 honda accord 4dr lx-i
    carotman's Avatar
    That's because the engine is a B21A which came in the Si model in 90-91
    I need these parts!
  1. Replies: 2
    Last Post: 07-05-2002, 03:37 PM
