Page 17 of 19 FirstFirst ... 713141516171819 LastLast
Results 401 to 425 of 475
Thread: 2nd & 3rd GEN ACCORD WEBER 32/36 & 38 HELP
  1. #401
    Re: 2nd & 3rd GEN ACCORD WEBER 32/36 & 38 HELP
    I think you may need help with the basic understanding of how the automatic choke works.
    The choke will not close until you mash the throttle to release or unbind the choke butterfly off the throttle stop.
    Once that happens the stepper for the fast idle comes up, there is a rod on the opposite side of the throttle connection that handles that. Only like five pieces we are talking about here...Pm if you want
  2. #402
    May 2008
    FYI to anyone, I'm getting about 22-25mpg with the Weber. Not super impressed, especially since the how to said the stock Klein linkage was the best, so I did that but the pedal travel does not have enough 'travel' to let the car idle reasonable, AND hit WOT. So my car is "slower" than it was stock, because I can't get to WOT thanks to the tip of using the Klein's linkage. Anyway.
  3. #403
    Quote Originally Posted by jdmaccordnut View Post
    don't blame the equipment, you just had to chime in with this BS? I was getting 29 mpg with mine, dogging it all the time or not same mpg consistant. Hell even the 38 weber Im using now on the other car is getting 25-30 mpg.
    I could have tuned it closer to get better mpg.
    The only thing you use is the cresant shaped cable retainer so you can use the same cable with out cutting it. that actually provide MORE travel than the junk pack weber sends out.
    Never did see any pictures of your set up, you being all techy savy and all what was the problem? I could help you with it, gladly. automatic tranny? tricky is the set up for those using a weber but I can guide on that too.
    Not meaning to sound as condesending as you, but I am standing by for a spelling grammer error comment.lol
  4. #404
    LX User greentee76's Avatar
    Feb 2008
    1988 Honda Accord LX 5sp
    Kalamazoo,MI
    Take the bracket that holds the cable off the front of the carb and make a spacer to move it one inch toward the front of the car. This will fix this "problem". Mine was not exactly perfect with just the bracket provided in the kit but I was able to get WOT and a larger return spring corrected the issue of the throttle not returning all the way like I said a month or more ago.
    The Weber conversion is the best money I've ever spent on the car and making it work correctly is not rocket science, but maybe beyond your capabilities.
    88 LX 5spd l 32/36 weber l KYB GR-2's l Refreshed A20A3 engine l
  5. #405
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    I wonder why your pedal doesn't have enough travel. I've set up the weber on two cars and both could idle around 500 and open the throttle plates all the way.
    You can't use the stock keihin linkage as it though, the reason for it being so good is that it has a smoother operation then using stock weber linkages.
  6. #406
    Quote Originally Posted by greentee76 View Post
    pretty much exactly how to resolve this issue, good post greentea!
  7. #407
    May 2008
    I'll post pics in the next few days
  8. #408
    May 2008
    Here are some pics
  9. #409
    I owe you some pics of mine. Been too busy with something else lately.
    It looks like you need to dremel cut some of the metal of that oem piece. Also there is not enough shaft showing at the end of that nut, it could fall off possibly. The cable does not look quite right either, hard to tell you why without my pictures.
    I can see why you are having some problems there.
  10. #410
    May 2008
    Like the chrome valve cover? Woot. Anxiously awaiting your pics!
  11. #411
    I was looking at that valve cover and thinking something looked different, it is chrome, saa weeet
  12. #412
    May 2008
    Well I put in new plugs, and redid the distributor, oiled the bearings, new rotor, new cap... still doesn't run worth shit in the cold. Dies instantly. Why? So now what I do is stab the gas while I'm braking every few seconds to keep the engine alive.
  13. #413
    DX User SaNeen's Avatar
    Aug 2009
    2nd 3rd GEN ACCORD WEBER 32/36 38 HELP
    6th gen subforums added. please begin to use them and help us keep this place organized for every ones benefit
  14. #414
    [IMG][/IMG]
    compare the stock vs modified intake manifold opening, I had them both out and decided to share this
  15. #415
    Damn, big difference! Is the entire dividing wall removed out of that one?
  16. #416
    Yes, that one was Cygnusx1's masterpiece.. here is the one I made for the B20a
    I added those divots to help eliminate pooling under the 38 Weber but after a summer of using it that way I think it actually richens the mixture too much once the outside temps get under 70 degrees or so.
    Divots were to allow smaller pooling and quicker evaperation "spreading out the liquid"
    I suppose yet another reason to use sidedrafts, meh
  17. #417
    Jul 2010
    How do I plug the one on the exhaust manifold?
  18. #418
    LX User Xaisk's Avatar
    Feb 2010
    1989 Accord Sedan
    Oklahoma City
    I have a question. How do I hook up the vacuum canister with the weber? I know the routing of the 2 fuel lines but it also has some vacuum lines that go to it.
  19. #419
    LXi User SZfiftyfour's Avatar
    '82 Accord DX Sdn
    Ocala, FL.
    Theres two vacuum ports on the back I think. One is for the vac advance the other is extra. Or you can 'T' off of the brake booster line.
  20. #420
    Feb 2010
    1989 Accord Sedan
    Oklahoma City
    Oh so I can just unscrew that extra one with the little cap and run that to the vacuum canister? alright thats ez enough.
  21. #421
    Feb 2010
    1989 Accord Sedan
    Oklahoma City
    So I took my vac canister out and noticed that there were 4 lines on it. One to tank, one to carb, and I suppose the 2 other ones go to the vacuum. Or one of em just went into a filter in the black box and just pulls air in.
    Does the top one that hooks to the little solenoid go to the vacuum? or does that one just hook to a little air filter and the bottom one hooks to the vacuum?
    Im going to look at my manual and see if it has the routing and what it does.
  22. #422
    I removed the canister on all mine and just left the vent tube hanging out of the firewall. There is a routing techique here somewhere though if you wish to retain the canister though.
  23. #423
    DX User 86dxhatch's Avatar
    Oct 2010
    86dx hatch
    Venice, FL
    Has anyone used the charcoal canister with a Weber yet? I would think that its purpose, "scavenging vapors" would help improve mileage?
    I would like to retain it with the Weber, but don't know what to do with routing the lines.
    I kept my vacuum bottle and just hooked up both ports to manifold vac.
    Any help with the hose routing would be awesome.
    Also, anyone know where the big tube coming out of the bottom goes to? Fuel tank?
  24. #424
    Apr 2011
    '89 Accord LX
    BC, Canada
    I'm in the process of my Weber conversion, and know little about carbs, so excuse the stupid question. Is this (middle of pic) a vacuum line for EGR?
    Thanks.
  25. #425
    LXi User CzEcHy's Avatar
    Jul 2008
    89 Accord LXI
    Gulf Breeze, Florida
    It can be, its just a vaccum port really but I believe using it for the egr is its purpose, tho not using egr is fine also.
  1. 77 Accord update - Weber!
    By bluesky6 in forum 1geez Tech & Performance
    Last Post: 12-21-2011, 04:26 AM
  2. Weber Swap Into '79 Accord Hatch
    By forrest89sei in forum 1geez Tech & Performance
    Last Post: 04-04-2011, 10:05 PM
  3. Weber carb in 88 Accord.
    By Xaisk in forum Performance
    Last Post: 03-06-2010, 06:28 PM
  4. Weber installed on 2G accord
    By it's paid for in forum 2geez Accords
    Last Post: 04-07-2004, 12:00 PM
  5. 87 Crx with weber.....will it fit my accord?
    By bradccool in forum Carburetor Tech
    Last Post: 03-16-2003, 04:28 PM
