Page 15 of 19 FirstFirst ... 5111213141516171819 LastLast
Results 351 to 375 of 475
Thread: 2nd & 3rd GEN ACCORD WEBER 32/36 & 38 HELP
  1. #351
    LX User Darkside's Avatar
    Feb 2002
    A20A1 Weber Power
    Eugene
    I'm going to Dyno mine this summer at Matrix motor sports in Portland. Others should go as well.
    DARKSIDE
    WEBER POWER!
  2. #352
    Re: 2nd & 3rd GEN ACCORD WEBER 32/36 & 38 HELP
    OK I was just reading this entire thread again.. wow lost links pics everytwhere. I hope someone can put some of them back up, or they are gone forever..lots of good work, that reminds me of something Kim Komando was saying on the radio this am, computers are not forever, if you have memories in photos you best print them out....
    anyway. for inquiring minds check this out.....
    Quote A20A1
    OK here is the Venturi size for the Keihin vs the weber 32/36
    KEIHIN:
    -PRIMARY BARREL ~22.225mm
    -SECONDARY BARREL ~31.75mm
    WEBER:
    -PRIMARY BARREL 32mm
    -SECONDARY BARREL 36mm
    Now tell me which carb sucks more...
  3. #353
    2ndGenGuy
    Guest
    Quote A20A1
    KEIHIN:
    WEBER:
    Really? The 2nd gen barrels are 32mm and 34mm respectively. 22/32 seems a little odd. I could be wrong on my barrel sizes, but thats what I got when I measured last time.
  4. #354
    just posting what was posted by A20A1. There were two different carbs, some were "three barrels" so that spec may be from one of the two different carbs.
  5. #355
    i think it was venturi bore diameter not throttle bore diameter
  6. #356
    I ran across some information on a 4X4 forum (4 and 6 cyl vehicles).
    Even though you can get by without a regulator using the 32/36, it is a good thing to use one anyway. The fuel can be atomized slightly when the needle opens because of too much pressure (8psi and more with oem fuel pumps) and the Weber is designed to work best on 2.5-4 psi, thus you will get a lot of fumes which could be causing over rich condtions randomly, also makes carb gaskets seep. Using the regulator will remedy a lot of seasonal retuning issues as well.
  7. #357
    May 2008
    I've read the install how/to over and over, but it doesn't mention what to do with the hot air pipe, coming off the exhaust manifold attaching to the stock intake snorkel. What do I do with it? I have the black box taken out, so far so good. Will have the carb out after eating some food.
  8. #358
    there are two , one goes from the exhaust to the actual intake manifold, that is egr
    the other one (larger) goes to the Air pulser, you can take that completly off and plut the pipe to the exhaust.
    The flexable really light plastic one is hot air duct that goes to the old air breather, you just have to put that up for a while, you wont be able to use it on the standard weber air cleaner.
  9. #359
    May 2008
    How do I plug the one on the exhaust manifold? The how to never mentioned that. :\
    Plug it with what, quicksteel?
  10. #360
    Quote Originally Posted by jdmaccordnut View Post
    which one? what I did was cut the flange nut off both of them and welded in a washer and then made them solid plug offs, screw them back in.
    You can cut them short of the flange nuts and pinch the tubing together and fold it ,hope it don't leak.
  11. #361
    May 2008
    Alright, all emissions garbage is out, and things are going along nicely. I plugged the coolant hole in the manifold with quicksteel, and tomorrow I need to pick up some vaccuum plugs. The big thing I'm still unsure of is the throttle bracket. The how to here says "by far the best way to setup the weber linkage... use the old keihin carb linkage from the stock carb (modification necessary)."
    Okay, uh, what modification? It says nothing about what needs to be done, and I'd really like to do this right. Can anybody go into detail on how to swap the throttle linkages?
  12. #362
    May 2008
    Quote Originally Posted by A20A1 View Post
    it turns out you have to drill it right on the bend, after you flatten it... then stick it in a clanp and bend it back out a little and install the stud.
    and you have to slot and drill a hole lower on the cable bracket.
    It's was awlful... but then i didn't buy the kit... I bought the carb on e-bay and ordered the rest of the parts later.
    Here is my set up. It shows the lower slot on the cable bracket.
    I had to add some odd bits so I assume my linkage will look nothing like yours.
    note that I added a support bar or pivot to give the cable some leverage (right)... that will keep the cable from snapping or tearing the linkage apart.
    Without the support the cable would not be able to rotate the throttle linkage smoothly.
    I also added a brace for the cable bracket (left)... I notticed that little by little the bracket was leaning forward.
    Pics? Drawings? Something?
  13. #363
    May 2008
    Carb is in, car runs!
    Haven't tuned it yet, it still idles crazy high, but man is the throttle responsive. Holy crap. Anyway, I used the Klein linkage, I had to dremel out the hole a little wider to fit on the throttle shaft of the Weber, and remove part of it that was hitting the carb base. I also had to use a few washers to space it away from the carb body, so it wouldn't hit the weber linkages. Woohooo!
  14. #364
    May 2008
    Okay, just drove it around for 15 minutes. It currently idles at 2000-2500rpms. That needs to be fixed, but the really REALLY annoying thing is when I turn the car off it stumbles on and on and on and on. WTF. Nobody who was saying how great webers are mentioned this.
  15. #365
    awe come on now, it isnt the weber's fault.
    First of course , please no vacuum leaks or all idle adjustments are pointless.
    If that is all cool then you probably have the throttle stop idle screw adj too far in. Also make sure the fat rod on the opposite side of the carb, which is the fast idle for when the choke blade is closed, is not sticking or binding. It is just a matter of minor adjustments.
    BTW you also should have a little slack in the throttle cable.
    Post a few pics of what you got there so far, so we may see something that may not look right.
  16. #366
    May 2008
    Pretty sure I have no vacuum leaks. I plugged everything that needed to be plugged. I'll post some pics in a few minutes.
  17. #367
    May 2008
    My AS valve is unplugged, that is correct, right? It is pulsing air when I put my hand near the opening. The big issue is the throttle return spring. I have no idea where that is supposed to hook up to, so I hooked mine to the throttle cable itself, before it is mounted to the throttle cable mount thing. It's running better, but it still stumbles on at shutoff.
  18. #368
    I wouldnt advise putting the return spring on the cable, you may need to get a universal spring, longer, that will extend to something you can rely on.
    Sometimes, when you put those studs in, and you tighten the nuts for the carb.. you can inadvertently turn the studs in too far and push the adapters apart.
    On the AS valve you can remove the whole friggen thing, and plug off the tube like I decribed in the other thread.
  19. #369
    it should be all here
    https://www.3geez.com/forum/showpost....13&postcount=2
    let the pics load it may be slow.
  20. #370
    2ndGenGuy
    Guest
    Vacuum leaks come from around the base of the carb and the adapter plates. I use aerosol cans full of butane (used for refilling my soldering iron) and spray the butane at the carb base. The vacuum leak will suck the gas in and the car will accelerate slightly or stumble. It's REALLY REALLY REALLY important that you make sure there are no leaks.
  21. #371
    LX User greentee76's Avatar
    Feb 2008
    1988 Honda Accord LX 5sp
    Kalamazoo,MI
    The car is running on because the throttle plates are still open when you shut off the car. I had this problem when I first did mine.
    IMO the return spring that comes in the kit is crap. I ended up using a return spring from a diesel truck I had kicking around here at work.
    As for where to hook the return spring I used an L bracket on one of the rear bolt holes on the intake that the vacuum tree bolted to. Sorry I don't have any pictures.
  22. #372
    May 2008
    There was ONE pic of the Klein, and it says it needed mods. No information on what needed to be done. For the record, I had to dremel out the hole a little wider to fit on the throttle shaft of the Weber, and remove part of it that was hitting the carb base. I also had to use a few washers to space it away from the carb body, so it wouldn't hit the weber linkages.
  23. #373
    May 2008
    The how to used the pic of the AS valve above, and said that was as much as you could remove. I can unbolt all of it?
  24. #374
    May 2008
    Pics!
  25. #375
    Yes you can remove the As valve but you must plug the hole in the exhaust manifold with a cap or remove the pipe from the manifold and weld the pipe shut or crimp it shut, then install the sealed pipe back on the exhaust manifold to plug the hole.
  1. 77 Accord update - Weber!
    By bluesky6 in forum 1geez Tech & Performance
    Last Post: 12-21-2011, 04:26 AM
  2. Weber Swap Into '79 Accord Hatch
    By forrest89sei in forum 1geez Tech & Performance
    Last Post: 04-04-2011, 10:05 PM
  3. Weber carb in 88 Accord.
    By Xaisk in forum Performance
    Last Post: 03-06-2010, 06:28 PM
  4. Weber installed on 2G accord
    By it's paid for in forum 2geez Accords
    Last Post: 04-07-2004, 12:00 PM
  5. 87 Crx with weber.....will it fit my accord?
    By bradccool in forum Carburetor Tech
    Last Post: 03-16-2003, 04:28 PM
