lostforawhile
since it was already brought up, simple explanation as to how the charge warning light works, when the key is on, and the engine isn't started, the warning light bulb, will have 12 volts on one side, and negative on the other, from the blue/white wire at the alternator so the bulb lights, when the alternator is charging, the output of the blue/white wire changes to a positive voltage, this means there is +12 volts on both sides of the bulb, so it stays off. this same change also sends a signal to the ECU in fuel injected cars, the multi function box under the radio, and several other things, on the DX and LX cars it also powers the choke heater coil, and sends a signal to the control box for the carb,
