I have been told its a problem with my carb but idk whats going on. Sometimes the car runs fine. Then sometimes the idle just dies and while its struggling i can hear a slight backfire. Can anyone help??
How does it start when its warm and when its cold.
1988 Honda Accord LSDX-I
Sometimes it starts up normal. Idle goes up to about 2800-3000 then goes back down to normal. Then sometimes it struggles to start idles up to adout 2000 and dies.
Mine used to do this and I think it is the automatic choke. If you give the gas one full push to the floor and let up fast right before cranking it can help. The idle will climb real high for a second, but then you tap the gas and it will drop to normal again. This only happens with cold starts, but if the car has run in the last 15 - 20 minutes it starts fine.
1987 Accord Sedan LX KL 5MT in Sonic Blue Metallic - 2.5" lowering springs
First thing to check on these carbs is the vacuum hoses. There are a lot and they are old. Look for disconnected and brittle hoses. Also with the car running, spray some carb cleaner around the outside of the carb by the vacuum lines. If the idle increases during a spray you have a leak in that area. It doesn't take much of a spray btw.
Cleaned the carb and been running carb cleaner and it seems to have fixed the problem
