What does the se-i proportioning valve look like? Were is it located exactly (is it the braket thing in the front of the wheel well)? Also for the Se-i rear brake swap, do we need the emergency brake cables or will just the valve do? Thanks
it is on the left side of the engine bay kind of above the battery. It will be a silver chunk of metal with 4-5 brake lines coming out of it.
For the sei brake swap, you'll need the cables. Look at the how-to.
you can a part of it in the verry bottom-middle of this pic (it has a metal tube coming out of it)
Ok, thanks guys.![]()
