I am deep into the timing belt replacement procedure. I see signs of some oil seepage around the oil pump sprocket. Oil pump seals seem to be hard to find. Advance Auto Parts seem to have one. Does the seal shown at National Oil Seal 221620: Purchase the best Pump Shaft Seal at Advance Auto Parts look like the right seal?
Does the oil pump sprocket just pull off like the crankshaft sprocket?
Edit: I see 10 mm bolts next to the oil pump sprocket. Do they hold the oil pump sprocket? The 10 mm bolts appear to hold a plate/base/stand which contains the oil pump shaft. Is this right? Does that plate/base/stand have a separate gasket that might need to be replaced?
