Results 1 to 11 of 11
Thread: Fuse box under the dash
    Oct 2002
    1987 honda accord lxi
    Bronx new york
    Angry Fuse box under the dash
    ok i have aproblem with the fuse box under the dashboard one of the fuses is loose in there and everytime i go to put my signals everythng on the dash shuts off except for the speedometer can anyone please tell me how to fix it or do i need a new one and by the way i replace the fuse and still keeps on the fuse is loose in the socket coult that be the problem????
    El Gordo Peligroso
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    Lightbulb
    If the fuse is loose in its socket, then it mat not be making good contact with the circuitry and therefore will cause intermitent operation. The position of the fuse box under the dash is not very convenient for fuse replacement. You could try to lower the fuse box off of the bolts. This is rather easy once you get the nuts that hold it to the dash removed. Unless you need to remove the fuse box comletely, it is not neccesary to remove the wiring from it. Did your fuse just suddenly start to vibrate loose or did you do any work around there and accidentally pulled on it. You say that any time you turn your signals on, the whole dash goes blank, yet if you reinsert the fuse all the way, it starts working?
    A little more detail could help. You may want to try and get the fuse box out of the dash and have a better look at it.
    Hope this helps.
    The RUS.:pimp:
    3axap.
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    hmmm..sticky tape
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I would tape that sucker down or would it be up? Sticky tape.
    Oct 2002
    Bronx new york
    nah the fuse is all the way in yeah sometimes it starts to viberate real fast but its still in there and the way i fix it is by putting a peice of cardboard between 2 fuses and it stays in place for a while but ima try that lowering the fuse box to see what happens.
    El Gordo Peligroso
    Nov 2002
    Ridin Dirty in New York
    2 words... Rubber Band
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    BTW, when I said to lower the fuse box I didn't mean that it would be done permanently, only to have a better look at it. The fuse box sits on two studs so it would be rather hard to reposition it to a lower area. If you don't want to remove the fuse box for inspection you can get to the fuses from the bottom but you will have limited access.
    Just clariying myself. Don't want to confuse anyone more than necessary.
    3axap.
    10/Honda/Ridgeline
    NJ
    Rubber band is three words mind .
    Well if u dont wanna have it ghetto style taped in, go get a another whole fuse box, its not hard to find. Hey i got one if u want to.
    Oct 2002
    Bronx new york
    Womp Womp Womp i knew that lol nah but thanx for ya help i just fixed it there was sumething stuck inside the socket so its working fine now again thanx alot guys...
    El Gordo Peligroso
    10/Honda/Ridgeline
    NJ
    i was just kidding about that man. Anywayz, what was it? was it a broken plastic part of the fuse or some shit? cause some of the cars i come across in the junk has some broken fuse parts in it.
    1988starter
    Guest
    I just reshaped one of my fuse connectors so it had a hump stays in good now needle nose pliers.
  1. Slots 1,2,3 under dash fuse box ?
    By Rendon LX-i in forum 3geez Accords
    Last Post: 06-26-2012, 07:08 AM
  2. Where is the radio fuse on the fuse rack??
    By Stoff81 in forum Interior & Exterior Care
    Last Post: 10-09-2010, 01:59 PM
  3. Dash, Dash lights, clock, turn signal all not working?
    By Josh89accord in forum 3geez Accords
    Last Post: 09-06-2008, 07:45 PM
  4. Fuse help
    By EducatedFool in forum Carburetor Tech
    Last Post: 05-19-2006, 04:59 AM
  5. dash light fuse pops
    By 86accordlxi-fi in forum 3geez Accords
    Last Post: 11-28-2002, 06:24 PM
