Ok so I've got a big issue with my accord.. It's running WAY rich, shaking and not turning over.. Sometimes. It runs like a dream one drive and like a bomb the next. I've had this car in a good shop, the guys checked EVERYTHING. Put it on all the diagnostics, checked fuel pressure, vacuum, map sensor, timing.. The lot. The only bad reading that comes up is the running rich. The only other issue found was a bad 02 sensor and burned out rotor button in the distributor. It's like it's possessed, my last option is replacing the entire distributor or injectors ( which just got cleaned last month ) the mechanic even suggested possible fault in wiring harness. I can't keep throwing money in it, any ideas? Anyone had similar gremlins? I need to get this sorted, it's doing my head in. Any feedback appreciated
