So a lot of threads talk about adjusting the timing and tweaking the fuel mixture (carb) but only as separate things. I would like to have my car idling as close to perfectly as possible but I would have to really do those two things. But in which order? If I adjust the timing but my carb is running rich, it will affect my timing, no? Likewise if I were to adjust my fuel mixture but my timing is off, it won't be perfect. The only reason I'd have to adjust the fuel mixture is that my carb was recently rebuilt and it would be nice to be certain the mixture is correct. And whenever I play even a smidge with the stop-throttle screw, it never seems to be consistent.
So what to do first? Timing the mixture or vice versa?
you guys are the best.
