3Geez resident body man
Owner of Wreck-less auto body
This sure is nice!
I wish I could convert my car harness with something like this
I need these parts!
I do a lot of electrical stuff all day, doesn't look hard at all to do like this as long as you have the connectors, wire diagram, and materials. So who wants to send me their harness
If you made a MT subharness for us MT swap guys, that would be awesome. Unfortunately, I don't have one and have no idea what one looks like. I keep meaning to go to the junkyard and keep tearing a car apart until I find it but haven't yet.
You know, it's a project. It's on the list.
I wouldn't mind making wire harnesses , just gotta provide the original harness for the first one made and the connectors. I can take care of the rest
I need a harness for Obd1 b series. What would ya need For that?
Sent from my SM-N900T using Tapatalk
you can send me one too.
un-motivated!
3GR
there is a jumper that goes in the harness that bypasses where the neutral safety switch would plug in, it's not so much of a sub harness on the manual cars, as the lack of the sub harness that would have gone to the auto shifter. It's in the electrical troubleshooting manual, it will show where the jumper plugs in
Hi gp02a0083 .... I am rebuilding my 85 Accord ....original engine died with 340K on it so it would be smart to install a new engine wiring harness. Here's a picture ... I'll send it to you with the wiring diagrams .... How much would you charge $ More detailed pics if you want them
Cell 678 492 1924
John
JKP Powder Springs GA
1985 Accord Hatchback LX (stock) 340K
2010 Odyssey EXL
1970 Jeepster Commando
I'm already making a jig something like this for mine.
I posted about this month's ago and it sounded like no one was interested. I was thinking milli spec to the fire wall then to the obd1 jumper (Victor is making for us) to the ecu. I think the jumper post is a sticky here.
Here's what I've gotten done.
Just need to pin it to a board, wire and plugs.
Rywire MiliSpec harness is the same one. i called them 3 weeks ago and they said they could make one for our cars. but now that you have a 94 teg they will be able to just plug in. but they are like 600 bucks just for the harness and more if you want to make it custom.
That's where I got the idea from sir
I could do that for less if i had measurements and a layout. The cost here really isn't in the labor, but rather its in the quality of the materials used. GOOD mil spec plugs will run around $30 or so alone. I use plenty of them at work and I switched my electrical department over to better connectors, the low end ones tend to eventually leak and the center guts become loose. Kapton tape is relatively inexpensive and works very well over a wide range of temperature and has excellent insulating properties.
So I just got my jumper harness back so now I want really get to work make a jig and start working on everything. I have come to the conclusion that the best thing to do seeing that you're add wires and get rid of some would be to Start fresh and make a mil-spec harness would be the best way to go in the long run. I would all make it pull and play. It's gonna take some time but I'll keep you guys posted
could u make a harness to swap a b18 from 1993 teg into a 1989 lxi
I got a guy looking in to getting all new connectors and wire right now.
thanks im gonna order the motor mounts iin november and i want the harness as well so i can do my swap let me know how much
