Results 1 to 14 of 14
Thread: oil pan plug tends to drip, should I try a different washer?
    May 2012
    central Ohio
    Any recommendations on type of washer?
    May 2012
    central Ohio
    Re: oil pan plug tends to drip, should I try a different washer?
    I just found a torque spec for the drain plug. The manual (from 3geez Wiki) says 33 ft. lbs. I have never used a torque wrench on the plug; I have just tightened it to what I felt was a safe level. Perhaps I need to start using a torque wrench to tighten the plug. I suspect I've been tightening less than 33 ft. lbs.; since I had not used a torque wrench, I was being cautious to not over tighten and possibly damage the oil pan.
    Stock pan Honda uses an aluminium washer. Susposed to change it everytime. Dealer only place i get them.
    May 2012
    central Ohio
    The washer on it is aluminum but it has been used numerous times. I couldn't see any reason the washer would need to be replaced every time. I'll change it next time and see if that helps. I see that the local Advance Auto Parts store sells an aluminum washer. I think I'll try that; Honda dealers probably charge several times more for the same thing.
    Oh, BTW, the manual confirms that the washer should be replaced every time. So, I need to think of adding a little more to the cost of an oil change.
    Nov 2006
    I've been reusing the washers many times, but polish them on a flat surface with 500-600 emery paper. Remove any grooves or marks from compression. I've never had one leak yet but still replace after reusing 5-6 times. 33 ft. lbs is very tight. I doubt I put that much on them, more like 15-20.
    LX User niles's Avatar
    Oct 2009
    87 LXi Hatch
    I buy the packages of the blue rubber oil pan seals, there's 3 or 4 in a pack and I have no leaks.
    Well as long as we're all exchanging notes, I use a regular flat washer smeared with RTV. At each change, I rub the old RTV off and put new on. Getting the special crush washers is a gigantic hassle for me (nearest dealer is 2 hrs away) and too blasted expensive anyway. Seems to be working well for the last few years.
    carotman's Avatar
    Montreal South Shore
    I've been using a nylon washer on my B20A. The oil pan was a bit smashed when I got the engine. I hammered it back into shape and welded a new bung on there but it always leaked a bit with the aluminum washers. The nylon has worked great so far.
    Dec 2011
    1989 Accord LX - Carbeurated 2.0L Auto
    Kingston, Ontario
    I've used all kinds of washers, basically whatever Honda or a parts store will throw across the counter at me for free when I think about asking. I've used copper crush washers, aluminum ones, and nylon. No problems whatsoever from any of these. I replace them every second or third oil change - ish.
    Jul 2009
    Somerville, Alabama
    I use a simple oring, just not a thick oring. It squishes when the bolt is tightened and makes a seal.
    Shaggy
    FF II/ETC I
    FWIW, a thick oring will squish out as you tighten the bolt and you'll have a mighty leak. I haven't tried a thin oring.
    Jul 2009
    Somerville, Alabama
    ^^I used a thick oring once. Changed it within 20 miles for the reasons Dr Snooz posted.
    Shaggy
    FF II/ETC I
    LX User vteckiller's Avatar
    Oct 2011
    1989 Honda Accord LX-I
    OR
    Copper Washer, like the type you use on a fuel filter. replace every single oil change.. go to ace hardware buy 10 for like $5 or less.
    LIFE IS SHORT, DRAG IT OUT!
    Feb 2004
    1988 LX Sedan
    East TN
    I use the blue, nylon washers from AZ or Advance, 14 mm size. A pack of 4 is like $2.99 and change them every oil change. Torque to 15-18 Ft-lbs with these nylon washers or they will flatten and leak with too much torque. The 30 Ft-lbs is for the aluminum washers.
  1. LED Washer Sprayers...
    By 89accordlxigentyers in forum 3geez Accords
    Last Post: 02-23-2011, 07:58 PM
  2. washer squirters
    By import racer in forum 3geez Accords
    Last Post: 02-17-2009, 09:42 PM
  3. washer trick
    By 89sei89dx in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-23-2008, 01:31 PM
  4. Washer Trick??????
    By Rendon LX-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-25-2004, 12:40 AM
  5. washer fluid
    By 88vert in forum Classic Honda Community Chat
    Last Post: 01-10-2004, 02:48 PM
