hey
i have carbed accord, and i was wondering if i can putt better fuel pump and presure regulator.
Does anyone makes better fuel pums than stock one? where can i get one?
and how do i check what is my fuel presure right now?
thanks a lot.
hey
thanks a lot.
Yes, you can put an external fuel pump to give you extra psi.Originally posted by shepherd79
hey
thanks a lot.
You can also install an external fuel regulator to adjust and fine tune the lbs. delivery.
To check fuel psi you will have to tap a fuel gauge in the main fuel line, after the fuel filter is fine. Actually they sell guages that adapt to the fuel filter similar to B&M Gauges as well (for our cars).
Here's a fuel regulator that i'm selling (from NOS).
his car is carbed Juan
shepherd79: EFI cars use around 20x more pressure in the fuel line than a carbureted model. With the stock carb you should not exceed 3psi, I've been looking for an alterative bpump cuz mine's on its way out and I don't want to pay $80 for a stock style one
Eric
