any body know any tricks for making the water pump removal eaisier?it's been so long since i replaced one,I have forgotten. of course you can't get to any of the bolts. I already figured i would have to drop the alternator down to remove the bracket, can the pump be put into place without taking the lower timing belt cover loose? I figure thats what is whining,the timing belt tensioner is new,the alternator is new,the power steering pump is rebuilt. the Ac compressor is dead and disconnected from life support. the only thing left is the pump. it's running a little bit hot at idle and is fine at higher rpms. it also heats up when the heat or defroster is on. I figure the impeller is gone and it loses pressure when the heat valve opens. like turning on two faucets. if the impeller is gone that also explains why it cools fine at higer rpms. it causes some cavitation due to it being worn. everything else in the cooling system is new,new radiator,new heater core,all new hoses,even the little ones. the belt isn't slipping eithier.
