Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
Thread: Intake manifold conversion ?
    Re: Intake manifold conversion ?
    I'm finally putting my car on the road this Friday. I take my car for a spin every few days &when I brake, I have to press all the way down to brake &it jerks sometimes. What do I need?
    Or what's wrong ?
    Might want to take this car to a professional mechanic and have them do a safety/drive ability inspection. Don't have any work done just get a list of whats wrong and estimates for work it needs. As around for a good shop that has a good rep in your area.
    Bad brakes,bad trans your list is growing and its not even on the road yet.
    OP the factory service manual is free to download off of the three geez wiki, I suggest you start there and read the entire section about your brakes, that will answer more questions then a hundred posts, the brakes probably need an overhaul, well within the scope of any backyard mechanic, they are straight forward with no surprises, check you calipers for leaks, replace all your old brake hoses, easy job, and not that expensive for rubber lines, pads and rear shoes, possibly rear cylinders, rear cylinders are so cheap, it's almost cheaper to replace then repair, master cylinder may be shot,possibly booster, everything can be done yourself, the brakes are the first thing I would go through on any car this old, being able to stop is number one priority
    Dec 2014
    Lostforawhile: Can you post a link for a fi swap for my a1
    for the A20, there should be a number of stickys in FI about this, you need a doner car to start with it's pretty involved
    DX User JSmythe's Avatar
    Oct 2014
    81 Hatch & 80 Sedan
    The South
    Quote Originally Posted by j3wman View Post
    Step 1: sell car
    Step 2: buy newer car
    J35 RWD conversion. Go big or go home.
  8. #33
    Quote Originally Posted by jsmythe View Post
    j35 rwd conversion. Go big or go home.
    lol
  9. #34
    Oct 2014
    Hey lostforawhile i have a 1989 lxi and i want it to get more power out of it. Its an EFI...I was wondering whats an FI swap.? My accord is stock and it beats rx8 on take off automatic. I want to smoke an rx8 with a build A20. ANY advice???
  10. #35
    Quote Originally Posted by kumartypeR View Post
    lots of searching and you already have FI if you have an lxi
  11. #36
    Oct 2014
    Ok i have an FI what mod could i do to gain more power. I wanted to put individual throatle bodies.
  1. Replies: 0
    Last Post: 08-27-2011, 02:44 PM
  2. Replies: 5
    Last Post: 05-02-2011, 08:19 AM
  3. Replies: 12
    Last Post: 01-14-2004, 06:48 PM
  4. Don't do the 88/89 intake conversion
    By Accordtheory in forum Performance
    Last Post: 08-19-2002, 09:56 AM
  5. 86/87 to 88/89 2 stage intake conversion
    By Accordtheory in forum 3geez Accords
    Last Post: 07-29-2002, 06:04 PM
