I've installed a 38DGES Weber on my 1985 Accord, 1.8L N/A, Manual 5 speed Trans, and went with 2" pipe from the CAT-back.
It idles nicely, but I get a bad stumble and hesitation on acceleration UNDER LOAD, at about 2000rpms, UNLESS I press the accelerator pedal a little further then it can "hop" over that stumble or flat spot. So typically how I have been getting over this flat spot is just by accelerating faster, so pushing the pedal down further then letting up after I get over 2000rpms. I can rev the car all day and will get no noticeable hesitation or stumble while parked.
Here are my specs and other useful information:
-Ported intake plenum (no middle divider).
-At 0 degree timing I have a smooth 770-790 idle (I don't know the degrees while revving).
-Both mixture screws are adjusted equally outwards (I would like to comment more on this below).
-I have not found any vacuum leaks.
-New fuel pump pushes 2.5psi minimum up to 3.5psi maximum.
-New fuel filters (both of them, at the gas tank and at the engine bay).
-New dizzy cap and rotor
-Fresh gasoline
-Uniquely weird hiccup sound coming from intake area while idling (sounds like a click noise sorta made with your tongue that happens about every second).
-Cannot hear that hiccup sound while revving even a small amount.
I am curious whether or not the mixture screws should be adjusted equally on this car since I read that on this page https://www.3geez.com/forum/carbureto...izes-dcoe.html
I have a hunch that the mixture screws shouldn't be equally turned out and that is why I'm getting that unique click sound from the intake area. I'm thinking it's not getting a proper fuel/air mixture to the cylinder every now and then, every other second or whatever. Maybe this is the cause of the hesitation and stumble...
However maybe I'm bonkers. I really want some help on getting this car to run correctly. Thank you!
