Results 1 to 5 of 5
Thread: Manifold Heater
    LXi User 1989se-i's Avatar
    89 Accord SE-i Coupe
    Jokelahoma
    Manifold Heater
    How do you take the manifold heater out? Is it even worth it?
    Performance Modz: Short Ram Air Intake, Custom Exhaust w/o Cat & Resonator, Cherry Bomb Turbo Muffler, Accel Coil, Removed AC
    Other Modz: Clear Blinkers, Purple Calipers, Accord Emblem On Dash, Winking Headlights
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Manifold heater? You mean, exhaust manifold heat shield? If you take it out, you'll damage the paint on your hood because of the heat.
    AZmike's Avatar
    Tucson, Arizona
    Leave the exhaust heat shield on. The engine works better with hotter exhaust. The less dense hot air moves faster and improves torque.
    If you're talking about the intake manifold, I'm not too sure.
    Why did you want to remove it in the first place?
    Mike
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    there are two lines that run across the manifold. one from the left and right of the carb. un hook them from the intake, nad put a straight line across the back of the engine to join the two sides of the main water pipe. this is nessesary when u do a weber conversion and it is a good source of gaining a few Hp when u live in a warmer climate, so ur carb isnt super hot.
    Travis
    Jokelahoma
    OOHH, the intake manifold heater is only on carbs? No wonder i had trouble finding it
  1. Replies: 0
    Last Post: 08-27-2011, 02:44 PM
  2. Replies: 5
    Last Post: 05-02-2011, 08:19 AM
  3. heater fan ??/
    By 3vg in forum 3geez Accords
    Last Post: 12-15-2003, 10:41 AM
  4. by passing manifold coolant heater?
    By Mantis88LX in forum Carburetor Tech
    Last Post: 04-03-2003, 02:03 PM
  5. manifold coolant heater
    Last Post: 03-18-2003, 03:45 PM
