OK. Im thinking of installing a intake manifold from a blacktop b20a engine on my gold top engine. From what ive heard they flow better than the gold tops intake manifold and also has the advantage of the dual runners.
What I need to know it will the black box off the blacktop work with my 1985 ecu and wiring loom. Since it has one more feature (the dual runner actuator) OR will i need to purchase some sort of electronic rpm switch to enable the vacuume actuator to open the runners at a certain RPM??
Also i note the blacktop intake manifold has one more sensor on it. Sits right in the middle of the manifold, water lines go to it. is it a IAC controller???? has a 2 wire plug in it. Im sure it will work without it as the fast idle valve on the back of the intake manifold is still there and will still work as normal.
