Results 1 to 17 of 17
Thread: TW Sensor Clarification
    LX User niles's Avatar
    Oct 2009
    87 LXi Hatch
    Hi All, I recently did some TW sensor troubleshooting because my car has been having a hard time cold starting. I have no engine codes.
    I want to clear up some misinformation I came across when reading multiple threads here on 3Geez. This may not be the case for all 3Geez so this is confirmed for an 87 LXi Hatch.
    The TW sensor Autozone part number that has been thrown around is incorrect, it is NOT SU4006, and that goes for 5S1468 too at RockAuto. I picked one up and had to return it because the tab on the plug was different. The correct sensor was in fact SU410.
    Honda Part Numbers:
    TW Sensor = SU410 = 37870-PD6-003
    Thermo Switch = SU4006 = 37773-PJ0-661
    So to be 100% sure you get the right sensor follow these two easy steps:
    1) - Preform proper troubleshooting: Download Service Manual
    2) - Compare the tabs on your defective sensor to the replacement sensor
    Re: TW Sensor Clarification
    Good to know. Thanks for pointing that out.
    Very well done.
    Can we get together and get some pictures of the sensors on the car? I got a J code 88.
    Be a good sticky when finished.
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    excellent write up niles
    3Geez resident body man
    Owner of Wreck-less auto body
    Oct 2009
    87 LXi Hatch
    This is interesting, I was reading the engine code check post in the How-To section and noticed that not all 3Geez are the same. https://www.3geez.com/forum/how/81283...odes-pics.html. 89 LXi has a different TW Sensor. Check the pic attached to the Code #6 section taken by ShyBoyCA6. I think that's an 89 in the picture.
    So here's mine: 87 LXi - I've never messed with these before but maybe a previous owner had?
    Well ok here is mine. 1988 3 door accord lxi. its a J code car build date 1987.
    Looks opposite?
    This is the thread I reference. I didnt realize the picture links are dead in it until today.
    https://www.3geez.com/forum/efi-tech/...tw-sensor.html
    Oct 2009
    87 LXi Hatch
    Looks opposite?
    It looks like the tabs on your sensors are both on the same side. Can you confirm that? I am starting to think it might be a pre/post-facelift thing.
    Quote Originally Posted by niles View Post
    I think it is. The early FI cars where a little different than the later ones.
    I would go by the wiring. I see 2 wires on my plug on the left.
    Ill get some pics tomorrow I am a bit down on a sore neck and just come from the chiropractor.
    Oct 2009
    87 LXi Hatch
    Thanks for your help oldblue. I was able to at least confirm which is which. Only one sensor will trigger the code 6, and for me its the SU410 sensor.
    My sensor wire colors:
    TW Sensor: green/white stripe and yellow/green stripe
    Cooling Fan Sensor: white/green stripe and black
    tabs look nearly identical to me?
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Started working at O'reilly's a couple weeks ago and it looks like their part number for the Tw is 17-1236 I got in, gonna put it on tonight
    ill put this up as a sticky if some other people can verify this info.
    This unplugged causes a code 6 on the ECU.
    Two vids to help understand its operation a little better.
    Second one is with the sensor plugged back in.
    I highlighted the 200-400 ohm reading as important with the car fully warmed up.
    Dec 2023
    1986 Honda accord LXI, 1989 Chevy Camaro, 1990 Chevy s10 and 2002 Buick century
    https://youtube.com/shorts/kbfqZ053X...K6KC2Wp-CN2dWc
    This is my accord and I have a code 6 is this idle a result of the code 6?
    https://www.3geez.com/forum/showthre...29-Where-is-it
    In this post shows the sensors mine the one in the yellow box is corroded is this causing the rough idle and rough start or is it a vacuum leak
    Last edited by Oldblueaccord; 01-05-2024 at 02:09 PM. Reason: Tried to inbed video no luck
    Quote Originally Posted by SamKCMO View Post
    If it has code 6 I would fix the connector, test the ohms of the sensor or replace it.
    When the sensor fails you car runs very rich.
    May 2024
    1987 Accord LXi
    Corvallis, OR
    Figured I would share that the O'reilly part number mentioned above seems to have since been updated. The part number now is 17-1237.
    I just replaced the TW sensor on my 87 and the O'reilly 17-1237 was a perfect fit.
  1. cylinder position sensor and TDC sensor
    By newaccorddriver in forum EFI Tech
    Last Post: 04-21-2011, 10:02 PM
  2. Coolant temp sensor tw sensor
    By Bluntman in forum 3geez Accords
    Last Post: 07-06-2009, 06:12 PM
  3. Need help! Broke a sensor wire (green sensor)
    By SMaurer32 in forum EFI Tech
    Last Post: 10-31-2005, 08:06 AM
  4. b20a question/clarification
    By LXaccordian in forum General Engine Swaps
    Last Post: 12-13-2004, 06:31 PM
